'47 Power Wagon Trans Leak #1732892
01/18/15 01:49 PM
01/18/15 01:49 PM
IN
ahy Offline OP
ahy  Offline OP
IN
I just pulled the transmission from a '47 PW to replace the oiled clutch. There was noticeable gear lube on the transmission input shaft which seems to be the source of the oil on the clutch. I pulled it apart (pic attached).
The "seal" is a labyrinth or "screw" seal with drain back to the case... no lip seal. All parts seem present and correct per the service manual. I did operate it on an extreme incline which could have flooded it but not sure.
Any ideas on how to dry this up?
Re: '47 Power Wagon Trans Leak [Re: ahy] #1732893
01/18/15 05:51 PM
01/18/15 05:51 PM
Iowa
Steve G Offline
Steve G  Offline
Iowa
http://www.dodgepowerwagon.com/wwwboard/index.html
These guys know almost everything about old power wagons, might try there.
Re: '47 Power Wagon Trans Leak [Re: Steve G] #1732894
01/18/15 10:10 PM
01/18/15 10:10 PM
IN
ahy Offline OP
ahy  Offline OP
IN
I'll have a look, thanks
Re: '47 Power Wagon Trans Leak [Re: ahy] #1732895
02/12/15 10:38 PM
02/12/15 10:38 PM
IN
ahy Offline OP
ahy  Offline OP
IN
Update. I had a look at the sites suggested... lots of stuff out there for these old trucks. I also looked the front retainer and screw or labyrinth seal over well... it all looked good. Also no practical way to add a positive seal.
I did notice there was no vent of any kind. I concluded the oil leak was either from extreme angle operation or heat and pressure pushing it out.
I made a vent using one of the top cover bolts... drilled it through and mounted a generic transmission vent on the head. It goes right through to the inside so its vented now.
Feltons clutch service in Chattanooga turned around a refaced clutch in a day and upped pressure plate spring pressure for good measure.
All together and works well. Now if it just stays that way
Re: '47 Power Wagon Trans Leak [Re: ahy] #1732896
02/13/15 12:28 AM
02/13/15 12:28 AM
N
NITROUSN Offline
NITROUSN  Offline
N
If there is not a vent it will vent through the shift tower.
