365" with weiand t-ram #173228
12/23/08 12:38 AM
12/23/08 12:38 AM
Anonymous OP
Anonymous OP
would you run 2 650 holley vac.secondary carbs or say 2 600 AFB's. i have the holley but only one afb.This is strip only with ported "576" heads with 2.02" intake,340 replacement heads.
In a gremlin body at around 2700lbs.
Re: 365" with weiand t-ram #173229
12/23/08 02:14 AM
12/23/08 02:14 AM
You got the Holleys, try them now and see if they are good enough for your ambitions, maybe 750 CFM vacume carbs are in your future
Re: 365" with weiand t-ram #173230
12/23/08 10:21 AM
12/23/08 10:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt care for the vac secondaries on my 340
when I was running a tunnel ram, they were too
inconsistant on opening the secondaries and I spent
alot of time trying to correct that. I finally picked
up a set of 750dp and the car ran quicker and more
consistant
Re: 365" with weiand t-ram [Re: MR_P_BODY] #173231
12/23/08 04:01 PM
12/23/08 04:01 PM
Anonymous OP
Anonymous OP
I have a pair of 750 dp but wouldn't that be a lot of carb for 365" motor.12.6 cr and engle kv-3 cam.250@.050 and .575" lift.Gears undertermined yet,1/8 mile.
Re: 365" with weiand t-ram #173232
12/23/08 05:14 PM
12/23/08 05:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have a pair of 750 dp but wouldn't that be a lot of carb for 365" motor.12.6 cr and engle kv-3 [Email]cam.250@.050[/Email] and .575" lift.Gears undertermined yet,1/8 mile.
Absolutely not. Especially not if you go with Quick Fuel Annular ones. An annular boostered carb responds like a carb almost 200cfm smaller. I would run at least two 750dp's if not bigger.
