Starting to plan my M37 build. My last one had a 318 NP435 stock transfer case stock axle combo. My questions are around the NP435. I know where i can get one that was bolted behind a slant six 2wd. I think the trans itself is the same no matter what it was behind. But, I don't think the bellhousing or the flywheel will work. Can anyone confirm.
Also, what is the flywheel and clutch size for a small block? Are they all the same? Are tooth counts different?
New build will have newer axles and get me better brakes, gear ratio and tire selection.
