rear gear change #1728272
01/12/15 07:32 PM
01/12/15 07:32 PM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
I have an '02 2500 diesel pickup that I want to change the rear gears in. I've been told that I would have to have the computer re-programmed or change the speedo gear for the speedometer to read correctly. Is this true, and if so, what would be the easiest way to go?
Re: rear gear change [Re: poison_ivy] #1728273
01/13/15 04:05 PM
01/13/15 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Starting in '98 speedo drive gears were no longer used, the ABS sensor on the rear end gives a speed signal so a computer flash with a factory DRB or electronic adapter (tuner) is the only way to change the calibration.
Re: rear gear change [Re: John_Kunkel] #1728274
01/13/15 05:44 PM
01/13/15 05:44 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I believe you won't have to change anything when changing the gears. I went from 4.11 to 3.73 on my 03 and made no change to computer. Speedo is spot on.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: rear gear change [Re: Savoy1964] #1728275
01/13/15 09:47 PM
01/13/15 09:47 PM
dogdays Offline
dogdays  Offline
Lucky you. It was off before, then.
3.73s and 4.10s are 9 or 10% different.
On my 1993 suburban I was tired of the speedometer always reading fast. I replaced 247-75-16 tires with 265-75-16s and that changed the speedometer to almost exactly dead on.
It is nicer to be able to correct things with a change to the software, though.
R.
Re: rear gear change [Re: dogdays] #1728276
01/14/15 04:20 AM
01/14/15 04:20 AM
ND
dodgedon Offline
dodgedon  Offline
ND
like what was said above... The speed is a factor of tire size and axle RPM's from the ABS in the rear axle. So I don't believe changing the rear ratio would change the speedo. The speed sensor ring Diameter is the same, no matter which ring gear is used. Changing the tire size would. Not sure how GM does it but, a 93 suburban is not a 02 03 Dodge.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: rear gear change [Re: dodgedon] #1728277
01/15/15 05:00 PM
01/15/15 05:00 PM
dogdays Offline
dogdays  Offline
Okay, I had to step back and think.....You're right, changing only the gear ratio won't change the speedometer, but changing the tire size no matter what the gear ratio is, will.
It's true, I'm not up on newer trucks.
R.
Re: rear gear change [Re: dogdays] #1728278
01/16/15 03:33 AM
01/16/15 03:33 AM
Visalia, CA.
P
P
Visalia, CA.
Got the truck out of the shop today after the gear change. Speedo is spot on. Truck feels just as peppy from a dead stop as it ever did. I swear, every time I get behind the wheel, I love this truck more and more!
