These retainers be OK with these Dual valvesprings #172807
12/22/08 03:28 AM
12/22/08 03:28 AM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I have a brand new set of Hughesengines 1107 dual coil valvesprings that have an Outer spring that measures 1.510 outer diameter with the inner spring having a inner diameter of .800
These are going on a set of 440 Source heads which i think have 11/32 valve stems with single groove?
I would like to have 10 degree locks and retainers.
Would this Comp Cam retainer work with my Hughes engine dual valve springs?
CCA-748-16 Outer spring outer diameter 1.550 with a Inner Spring inner diameter of .710
Re: These retainers be OK with these Dual valvesprings [Re: Blakcharger440] #172808
12/22/08 10:07 AM
12/22/08 10:07 AM
looks like the retainer is too small.
Re: These retainers be OK with these Dual valvesprings [Re: Blakcharger440] #172809
12/22/08 12:54 PM
12/22/08 12:54 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Bob,
We have the 10º locks and retainers that you need. Just give us a call. Should be able to give you as good a price as anybody.
Merry Christmas!
Kevin @ Hughes
