#1727481 - 01/11/15 07:43 PM hotchkis leafs and dr diff spring location kit?
buconine Offline
Loc: omahell, ne
Anyone one running the hotchkis leafs and dr diff offset spring kit on their a body? Getting ready to start ordering parts for my 69 valiant and wanted to make sure there weren't any compatibility issues. I read on another post that the hotchkis front hanger was for correcting geometry issues. I wasn't sure if this would cause any issues using dr diffs offset hanger.
Thanks!
#1727482 - 01/11/15 07:55 PM Re: hotchkis leafs and dr diff spring location kit? [Re: buconine]
Dan@Hotchkis Offline
Loc: Santa Fe Springs, CA
Depends on the different mounting location/eye position of his front hangers. At that point I would call our sales folks and see if they'll pull a kit apart for you and just sell you the leaf packs, bushings and u-bolt kit. Our A-body leaf uses a 1/2" front bolt, I'm not sure what the Dr. Diff setup uses.
#1727483 - 01/11/15 08:19 PM Re: hotchkis leafs and dr diff spring location kit? [Re: Dan@Hotchkis]
goldduster318 Offline
Loc: Lake Orion, MI
http://www.doctordiff.com/a-body-offset-spring-hanger-shackle-kit.html
I have been looking into this as well as I have the MP kit on my car that uses 5/8" front hangar bolts in case I wanted to switch to the hotchkis springs. I remember asking about the size of the front bushing on those springs and they are not the same OD as a stock spring so they can't just be changed in my case.
As you can see the Doctor Diff kit has 2 holes, and to me the upper location looks similar to those on the hotchkis hangars. They do come in 1/2"
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
#1727484 - 01/11/15 11:45 PM Re: hotchkis leafs and dr diff spring location kit? [Re: goldduster318]
DoctorDiff Offline
Loc: Polson, MT
Because Hotchkis springs are not made in standard A, B or E body lengths, they will not fit my offset hangers.
Contact info
#1727485 - 01/12/15 02:49 AM Re: hotchkis leafs and dr diff spring location kit? [Re: DoctorDiff]
autoxcuda Offline
Loc: So Cal
Do you mean width?
I run them with stock front hanger and shackles and length seems fine. Shackles are at good angle.
The Hotchkis dropped front hangers lowered my car too much for my TTI headers and rear tires so I just left stock ones on.
Edited by autoxcuda (01/12/15 02:50 AM)
Spring Fling 33
April 13 & 14, 2019
Woodley Park, Van Nuys CA
www.cpwclub.com
500+ show cars, 200+ swap, manf. midways
Malibu Cruise, Cruise-In
Free Spectator Admission!
#1727486 - 01/12/15 10:49 AM Re: hotchkis leafs and dr diff spring location kit? [Re: autoxcuda]
DoctorDiff Offline
Loc: Polson, MT
Maybe Hotchkis A-body springs are standard length. I don't think the E-body version is.
Contact info
#1727487 - 01/12/15 11:22 AM Re: hotchkis leafs and dr diff spring location kit? [Re: DoctorDiff]
I'll double check the numbers, but the only reason our segments are slightly shorter is because of the spring lacking arch under load.
#1727488 - 01/12/15 12:20 PM Re: hotchkis leafs and dr diff spring location kit? [Re: Dan@Hotchkis]
12valve Offline
Loc: Big Lake, WA
I have Hotchkis leafs with Dr. Diff spring relocation kit on my 67 fastback with no issues. Granted, it hasn't left the garage yet, but everything clears and bolted up with no issues.
#1727489 - 01/17/15 05:36 PM Re: hotchkis leafs and dr diff spring location kit? [Re: 12valve]
buconine Offline
Loc: omahell, ne
2 people running different hangers on them seems like a safe bet that it will work. Are there any other similar leafs on the market in case i run into any issues? The car will mainly be for autox and track days but will see occasional strip duty as well. Thanks for the info, gents!
#2325721 - 06/23/17 11:44 AM Re: hotchkis leafs and dr diff spring location kit? [Re: buconine]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: Covina, Ca
Bringing a thread from the dead. Anyone else have experience with this?
68 Dart GT Project Thread: Linky!
#2326096 - 06/24/17 11:45 AM Re: hotchkis leafs and dr diff spring location kit? [Re: buconine]
JRC Offline
Loc: Winnipeg, Manitoba, Canada
I run the hotchkis leaf springs that I added 2 extra leafs to each and have the Dr Diff offset hangers with no issues. This is on a 72 Dart with a 8.8 explorer rear end. Also with the extra leaves in the springs I run them mounted in the top hole in the front hanger.
Edited by JRC (06/24/17 02:12 PM)
#2326291 - 06/25/17 12:08 AM Re: hotchkis leafs and dr diff spring location kit? [Re: buconine]
72Swinger Offline
Loc: Nebraska
I run it with a E-body Hellwig rear bar and home made Caltrac setup. Once you get the bigger tires under it and the extra traction you will soon realize spring wrap is out of control. Still like the ride of the Hotchkis springs but thats it.
Mopar to the bone!!!
25,631 Registered Members
195,641 Topics
18 Power Wagon egr tick?
by Jambbii
5 minutes 32 seconds ago
WW-II History buffs should read....
by 360view
Today at 07:26 AM
1969 Plymouth Road Runner
by tomsjack
Today at 02:47 AM
How I keep track of my "Barn Finds"
by Devil
Yesterday at 11:43 PM
