Page 4 of 4 1 2 3 4
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726903
01/17/15 07:55 PM
01/17/15 07:55 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Did you try the other sides ball joint nut on it?
Or one of the old ones?
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: nomore65BelvJim] #1726904
01/17/15 08:09 PM
01/17/15 08:09 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
I tried it and it snags in the exact same spot. The other LCA ball joint seems to be fine, but I'm trying to set it into the LCA to see if I can thread it down further.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726905
01/17/15 08:18 PM
01/17/15 08:18 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I don't know how you'll keep it from spinning either, that's why I suggested a new Ball Joint a while back.
Sheldon
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: RUNCHARGER] #1726906
01/17/15 08:19 PM
01/17/15 08:19 PM
SoCal
SoCal
Sheldon
Makes sense. I must have overlooked your comment.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726907
01/17/15 08:25 PM
01/17/15 08:25 PM
SoCal
SoCal
Also, I'm having trouble removing the UCA ball joints from the spindle. I get the punch angled properly to pop the balljoint out with a hammer.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726908
01/17/15 08:25 PM
01/17/15 08:25 PM
RUNCHARGER Offline
RUNCHARGER  Offline
No that's okay, at that time I thought the stud was bent anyway. You might get it by fiddling with it and not jamming the die if you're careful. It won't take much to clean the threads enough for the nut to run on, use lots of oil with the die.
Sheldon
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: RUNCHARGER] #1726909
01/17/15 08:57 PM
01/17/15 08:57 PM
SoCal
SoCal
I just looked on Summit. Reading the reviews, it seems like other people had problems with smashed threads.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726910
01/17/15 09:06 PM
01/17/15 09:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's why I buy from the local parts store so I can return bad parts and not have to wait to reinstall good ones. The whole deal should have been a one day job.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726911
01/17/15 09:40 PM
01/17/15 09:40 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
The only way I ever cured a spinning ball joint is to put a jack under the lower ball joint and force the taper portion into he spindle until it stopped spinning.
Stop being an engineer and start forcing thing like a mechanic.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: moparpollack] #1726912
01/17/15 09:43 PM
01/17/15 09:43 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Bring it over and I can weld the ball joint stud to the ball joint so it won't spin.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726913
01/17/15 09:46 PM
01/17/15 09:46 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Hit the side of the spindle where the ball joint stud goes through, with a a couple times and it should pop loose.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: OzHemi] #1726914
01/17/15 09:46 PM
01/17/15 09:46 PM
85086
Lil Herman
Lil Herman
85086
That only works for upper ball joints!
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: OzHemi] #1726915
01/17/15 09:49 PM
01/17/15 09:49 PM
85086
Lil Herman
Lil Herman
85086
Yup use the force of the hammer!
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: moparpollack] #1726916
01/17/15 09:52 PM
01/17/15 09:52 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Once I fire up the welder, it is hard to stop..
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726917
01/17/15 09:52 PM
01/17/15 09:52 PM
NY NY
3
340duster340 Offline
NY NY
get a pickle fork and lube it up so you don't rip the boot. it will come right out.
or if you are coordinated enough a whack with a lump hammer directly to the top of the spindle should free it as well.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: moparpollack] #1726918
01/17/15 10:05 PM
01/17/15 10:05 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
ditto....Jack the lower BJ up into the control arm, unbolt it from the spindle and quit fooling with the upper BJ. Tighten the lower BJ up, put the cotter pin in and then put the 2 bolts in the spindle. Make sure you line the cotter pin hole up front to back!
...FAFO...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: skicker] #1726919
01/17/15 11:34 PM
01/17/15 11:34 PM
SoCal
SoCal
To be fair, the LCA ball joint castle nut is a total PIA to get to with the UCA balljoint in place. Although, your way doesn't sound too bad either. So I'm assuming the cotter pin will be a PIA if the hole is facing wheel to frame rails?
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: OzHemi] #1726920
01/17/15 11:34 PM
01/17/15 11:34 PM
SoCal
SoCal
I'll be right over!
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726921
01/19/15 11:21 AM
01/19/15 11:21 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Correct. Sometimes its a huge pita to remove the cotter pin at a later time when it runs from frame to wheel. When the LBJ is unbolted from the spindle lift the spindle and UCA up out of the way and strap it up in the wheel well.
...FAFO...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726922
01/19/15 11:53 AM
01/19/15 11:53 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
So, I think I'm going to head over to HF to get a tap and die set. When I run the threads how should I hold the part so the center ball joint doesn't rotate as I'm utilizing the die?
Kid someone beat on that ball joint stud, return it and get a new one. You try to run a die over those threads and you'll most likely make it worse and then you can't return it.
Page 4 of 4 1 2 3 4
