95 1500 ?
#1726731
01/10/15 11:12 PM
01/10/15 11:12 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
I have a 95 1500, 360 auto. The converter clutch has crapped out. It shakes the living he!! out of the truck when it engages. ?. Is there a way to disable it? It is fine other than that and it is not worth putting a converter in it as it is done after this plowing season. Thank you.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: 95 1500 ?
[Re: sixpackbee]
#1726734
01/11/15 06:15 PM
01/11/15 06:15 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The trans connector has three wires, the rear one (orange with a black tracer) is the converter LU.
Re: 95 1500 ?
[Re: sixpackbee]
#1726735
01/12/15 06:59 PM
01/12/15 06:59 PM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
Sure it is not a mis-fire? I have seen where the LU is blamed and it just apears that way as a mis shows up worse with the load on it. Those trucks suck enough fuel and have enough trans problems you don't want to add to them (cutting the LU wire will make the trans run hotter).
Re: 95 1500 ?
[Re: HotRodDave]
#1726736
01/13/15 02:45 PM
01/13/15 02:45 PM
sixpackbee
Western New York
We had it on the scanner for a day. No misfires but it does run a touch lean at speed. At first I thought it was a dead miss and was amplified by the lock up but we ruled that out. I have never seen a lock up issue so bad but the truck does have 318,000 miles so it is entitled.
