KB pistons/stroker??????????? #172569
12/21/08 07:33 PM
12/21/08 07:33 PM
griff70440 Offline OP
Hey Guys,
Has anyone used KB pistons in a stroker motor?
the reason I ask is because I was at summit yesterday and on the clearance rack was a set of 8 pistons for a BBM for $60 dollars.
I looked up the part#(kb251030-3)
they are a stephead piston and you can use them with a 4.150 or a 4.250 crank in a 440 or a 3.75 crank in a 400.
I`m wondering if they would be o.k for street motor?
thanks and MERRY X-MAS
mike
Re: KB pistons/stroker??????????? [Re: griff70440] #172570
12/21/08 08:30 PM
12/21/08 08:30 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Re: KB pistons/stroker??????????? [Re: griff70440] #172571
12/21/08 08:33 PM
12/21/08 08:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think they'd be fine in a street car. the compression is kinda low with a 440, about 8.9:1. i thought about building an 87 octane iron head 493 using those pistons. a 400 would have about 10.5:1 compression. i'd buy them for $60, if they were in o.k. shape.
Re: KB pistons/stroker??????????? [Re: lewtot184] #172572
12/21/08 10:04 PM
12/21/08 10:04 PM
thanks Guys, I did buy them.I figured that If I couldn`t use them, someone I know may be able too!
mike
Re: KB pistons/stroker??????????? [Re: griff70440] #172573
12/21/08 10:14 PM
12/21/08 10:14 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
mike
If you decide you cant use em, let me know.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
