How do I fix this? ***Updated***
#1724138
01/07/15 07:49 PM
01/07/15 07:49 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
1968 Valiant 273. Power steering. One of the bolts that holds the steering box in place looks to have been cross threaded before I got the car. It has broken the welded "nut" away from the K-frame. I had to cut the head of the bolt off with the torch to get the box out. Can this be fixed? See pics. Thanks Dave
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
Re: How do I fix this?
[Re: D149]
#1724140
01/07/15 08:06 PM
01/07/15 08:06 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Is the back side of the bracket blind? If not, I would just through-bolt it with Grade 8 hardware.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: VincentVega]
#1724141
01/07/15 08:11 PM
01/07/15 08:11 PM
D149
Ontario, Canada
Yes , that is a blind hole.
I am thinking about cutting the steering box mount above that bolt hole so I can weld a new nut in, then weld the metal back on to put it back the way it was. Hoping it will be strong enough.
[Re: D149]
#1724142
01/07/15 08:15 PM
01/07/15 08:15 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
The way those mounts move around in use it seems like the easiest way would be to cut the factory welds and do the repair in a vise. Then when it goes back on, gusset the heck out of it. Check the handling section here for the particulars.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: Stanton]
#1724144
01/07/15 08:30 PM
01/07/15 08:30 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Blow the rest of the bolt off with a torch. Find the correct size hex nut. Drill the existing hole large enough to fit the hex nut. use a long bolt in the nut so you can hold it in place in the hole - tack it in place then weld it completely. Grind it flush. DONE.
not at all skilled in welding but this is what I would ask a welder to do
[Re: Stanton]
#1724145
01/07/15 09:02 PM
01/07/15 09:02 PM
D149
Ontario, Canada
All good ideas.
I have no problem with welding.
Stanton. The problem with doing it that way, is I won't be able to get the rest of the bolt and old nut out of the blind hole. The original "nuts" are square and would require a large hole to get it out. The hole would be much larger than a new hex nut.
[Re: charles6970]
#1724148
01/07/15 10:12 PM
01/07/15 10:12 PM
D149
Ontario, Canada
The bolt is cross threaded in the nut. SO, I have to get the nut out.
super easy fix... Care to elaborate?
[Re: charles6970]
#1724150
01/08/15 01:34 AM
01/08/15 01:34 AM
Posts: 8,853 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
super easy fix...
Ya gotta love the morons that post these replies. Yeah, "super easy fix" ... but its a secret !!!
[Re: Jim_Lusk]
#1724157
01/08/15 09:53 AM
01/08/15 09:53 AM
D149
Ontario, Canada
I want to avoid pulling the K-frame if possible so I don't have to get an alignment after the work is done. I will get it all cleaned up today and make sure there are no cracked welds on the steering box mount. If there is, I will try to fix them on the car too. In the end, if the K-frame has to come out, so be it. Thanks for all the help. I will update on how things go.
