Bolt in roll bars for A-body? #172295
12/21/08 02:12 PM
12/21/08 02:12 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Anyone ever used one?
Who makes them?
How did they fit?
What did they cost you?
I'm getting close to the 11.50 range and need to think about adding one to my wife's '68 barracuda fastback but I don't really want to do anything permanent or cut up anything, especially since I just restored the interior a year ago. So I thought I'd look into bolt in options. I've got bold in frame connectors already installed. and I'm going to put cal-tracks on it this winter.
Let me hear your experiences with bolt in kits, please.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Bolt in roll bars for A-body? [Re: WadeMetzinger] #172296
12/21/08 02:50 PM
12/21/08 02:50 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Hi Wade,
You might check with Mike Cotton, he has probably used them in his Dusters at one time.
Bill Lamb
Re: Bolt in roll bars for A-body? [Re: WadeMetzinger] #172297
12/21/08 03:13 PM
12/21/08 03:13 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Ther was/is a company called Hobrecht that used to make a 4 pt bolt in roll bar for a body cars.Might want to do a internet search.
Nautilus Racing-
Re: Bolt in roll bars for A-body? [Re: WadeMetzinger] #172298
12/21/08 04:17 PM
12/21/08 04:17 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I just made my own. When you order your kit just tell them to send extra 6" X 6" plates and weld one to your bar and bolt the other under your floorpan with 4- 3/8's bolts. Where your rear bars leave the main hoop cut them about 4'' out and put a smaller about 6'' long bar inside and weld it at the bar end and bolt it to the other end with a 3/8" bolt that goes through both. On the side bars get a swing out kit and use half the kit at the tops of both bars and bolt the bottom with 2- 6" X 6" plates.
Re: Bolt in roll bars for A-body? [Re: drag440] #172299
12/21/08 05:43 PM
12/21/08 05:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats just what I was going to say as we welded the 6 point bar in my sons Dart but we could have gotten extra plates and bolted it in. I dont feel its as safe as welded but it can be done. Ron
Re: Bolt in roll bars for A-body? [Re: 383man] #172300
12/21/08 05:53 PM
12/21/08 05:53 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote I dont feel its as safe as welded but it can be done. Ron
Not as safe and not as rigid. I personally wouldnt put a bolt in bar in. Find a good builder and build it so it can be taken out later if needed.
If the Cuda should get on its top, what would you feel better about, bolts or welds protecting your wife?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Bolt in roll bars for A-body? [Re: WadeMetzinger] #172301
12/21/08 06:09 PM
12/21/08 06:09 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Pop for a weld-in one. While I understand your concerns about not wanting to cut things up, if you "use" the rollbar, you've already got bigger concerns than keeping things "original".
Re: Bolt in roll bars for A-body? [Re: hemicop] #172302
12/21/08 08:21 PM
12/21/08 08:21 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Are bolt in bars legal? Up to what et?
codfish
Re: Bolt in roll bars for A-body? [Re: codfish] #172303
12/21/08 08:44 PM
12/21/08 08:44 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
I used one for a while!!
Re: Bolt in roll bars for A-body? [Re: Diego_Ted] #172304
12/22/08 12:26 AM
12/22/08 12:26 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Dang Ted.. That cage looks very familiar...
Seriously.. I bought Teds cage and cut it up into a roll bar with swing out door bars.. It looks great inside the car
