Low gear sets
#172256
12/21/08 01:34 PM
12/21/08 01:34 PM
Posts: 2,902 A shed in England
Tig
A shed in England
Been thinking about changing to a low gear set (2.77 1.57 ) instead of the standard 727 ratio's (2.45 1.45). Anyone here do this swap? and did you improve et's? Just trying to find out if it's worth it. Thanks in advance. Tig
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Low gear sets
[Re: Tig]
#172257
12/21/08 02:20 PM
12/21/08 02:20 PM
my 60 foots went from 1.44-1.45 to 1.39-1.40 going 10.teens on a footbrake. the launch feels awesome, but dont use a gear lower than 4.10's,2nd gear comes up way too fast and you'll hurt your 60 foot and probably over rev by the time you shift to 2nd.you'll be in the air hitting 2nd gear.
Re: Low gear sets
#172258
12/21/08 03:21 PM
12/21/08 03:21 PM
Tig
A shed in England
Was all the improvement in the 60ft? did it carry thru to the 1/4 or did you find improvements at other increments? Must admit, I'm more than tempted to go this route
Re: Low gear sets
[Re: Tig]
#172259
12/21/08 03:45 PM
12/21/08 03:45 PM
getting out to the 330 as fast as you can with torque is going to equate to better ET. i love it but wont use it in a high HP car though. you dont need it. i think the cars that would see the best gains are slower heavy cars and for a mid to low 10 second car.havent tried it on any 9 second combos yet but this year im going to try it in my hemi belvedere with a totally different combo.car will be in the mid to upper 9's.
Re: Low gear sets
#172260
12/21/08 04:28 PM
12/21/08 04:28 PM
Tig
A shed in England
We've gone 1.39 60ft, 140 mph and low 9.70's on a few occassions now. Car weighs 3850lb and has 4:10 rear with 30 inch tall slicks, Still think it would work with this? Oh, btw, fwiw car wheelstands too, though we haven't clicked the 60ft timer with the rears we've been close a couple of times. Thanks for the reply's
Re: Low gear sets
[Re: Tig]
#172261
12/21/08 05:31 PM
12/21/08 05:31 PM
with the car weighing 3850, i think it could definitely help .should help get that log get going better.for 450.00 its worth a try. im going to mid to upper 9's and im leaving mine in.
Re: Low gear sets
[Re: BergmanAutoCraft]
#172264
12/21/08 07:52 PM
12/21/08 07:52 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Nick at Compu-Flo told me he tried them in his car (mid 9's) and he had trouble hooking it. Might want to give him a call,he is super nice and builds a lot of big block Mopars.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
Re: Low gear sets
[Re: High Impact]
#172265
12/21/08 11:20 PM
12/21/08 11:20 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Not to h-jack, but I've often wondered if it would help on a street car. I've got a 69 Bee with a built 383 and am running a 3.54 gear. I Often wondered if running a low gear set would help on the street, ya know,from street light to street light fun, yet still let you cruise nicely down the high-way.
I used them in my street Duster 518 C.I. low deck stroker, 10:30 ET and 128+mph on pump gas and ET Street Radails cork up on motor only Car weighs 3400 lbs with me in it I am using a ten inch Contintental street/ strip converter, 1:43 60 ft. best so far
Re: Low gear sets
[Re: Cab_Burge]
#172266
12/22/08 12:19 AM
12/22/08 12:19 AM
I use them in my cars...I run 4.30 gears with big inch stroker motors,Trick is to get out off the line and into high gear quickly and let the car MPH...
