Best way to remove rain drip mouldings with out damage #1721446
01/04/15 03:49 PM
01/04/15 03:49 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hello, I have an early 80's Dodge truck and I am doing some repair work to my shop truck and wanted to know if anyone has taken off the roof drip rail mouldings with out damaging them? The one I have is PERFECT and I don't want to damage it.
Re: Best way to remove rain drip mouldings with out damage [Re: GLR] #1721447
01/04/15 04:14 PM
01/04/15 04:14 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use a old school bottle opener & a folded up thick blue paper shop towel
Re: Best way to remove rain drip mouldings with out damage [Re: BulletBob] #1721448
01/04/15 04:22 PM
01/04/15 04:22 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Can you attach a picture of your "Old Scvhool" opener and are you using it on the bottom or the top?
Re: Best way to remove rain drip mouldings with out damage [Re: GLR] #1721449
01/04/15 05:24 PM
01/04/15 05:24 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
This is one from my box here at the house & is bent a little from too many Heinys or Coronas from friends being over
Re: Best way to remove rain drip mouldings with out damage [Re: BulletBob] #1721450
01/04/15 05:50 PM
01/04/15 05:50 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Original pic that's upside down
Re: Best way to remove rain drip mouldings with out damage [Re: BulletBob] #1721451
01/04/15 05:54 PM
01/04/15 05:54 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Upside down so it will be on the right
Re: Best way to remove rain drip mouldings with out damage [Re: BulletBob] #1721452
01/04/15 06:11 PM
01/04/15 06:11 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you.. I don't have any opers that look like that. I will see what I can find.. do you try to remove the molding from the top edge or the bottom edge?
Re: Best way to remove rain drip mouldings with out damage [Re: GLR] #1721453
01/04/15 06:29 PM
01/04/15 06:29 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The little tongue that catches the lip of the cap catches the lower edge
do this very progressively as you will warp them & they may not want to stay on when put back
The tongue will leave a small indentation sometimes but only on vinyl top cars & when trying to get too much at one time
always at least the beginning two starts get a little pulled spot
If it bothers you when put it back a rag & a body hammer will fix it
most of the time you won't notice it
Re: Best way to remove rain drip mouldings with out damage [Re: BulletBob] #1721454
01/05/15 03:28 AM
01/05/15 03:28 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use a paint stick, longways, then tap with a hammer... start at one end and work your way slowly to the other. You'll break the paint stick before you damage the trim.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Best way to remove rain drip mouldings with out damage [Re: Silver70] #1721455
01/05/15 04:05 AM
01/05/15 04:05 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have a few of these nylon sets and they work great:
Trim Removal Tools on Ebay
