MOUNTING DRIVERS SEAT QUESTION #172080
12/21/08 12:36 AM
12/21/08 12:36 AM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
What is the best way to mount the drivers seat? Mine is a plastic seat. Should it be close to the steering wheel, or should I stretch it out like I am driving a street car (stay comfortable). Keep in mind this is a drag car only. Also what about seat height. Where should eye level be at?
Re: MOUNTING DRIVERS SEAT QUESTION [Re: mopars rule] #172081
12/21/08 01:32 AM
12/21/08 01:32 AM
I try to move the seat over as close to the trans tunnel and as far back as I can and still safely reach the controls, usually end up with the seat back against the roll bar cross brace. the reason I do this is to get as much weight as I can on the right rear wheel and moved that weight back to the rear as far as I can
Post deleted by Defbob [Re: mopars rule] #172082
12/21/08 01:36 AM
12/21/08 01:36 AM
Re: MOUNTING DRIVERS SEAT QUESTION #172083
12/21/08 09:50 AM
12/21/08 09:50 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
whatever is most comfy and still be able to reach everything shifter switch pnl and so forth.
Re: MOUNTING DRIVERS SEAT QUESTION [Re: WILD BILL] #172084
12/21/08 10:09 AM
12/21/08 10:09 AM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
I think NHRA rules say the seat has to attach the cross bar for the main hoop. So if you don't mount it that far back you will have to make a support that attaches the seat back to the bar. If your car does not have a roll bar, the seat must be supported a different way.
Re: MOUNTING DRIVERS SEAT QUESTION [Re: mopars rule] #172085
12/21/08 10:16 AM
12/21/08 10:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The biggest thing guys dont do is tilt the seat back.
Tilt the front of the seat up so the bottom of the
seat supports the back of the thigh, this makes for
comfort. I like to mount the seat far enough back
that the driver can still press the gas pedal to
the floor and still reach the wheel
Re: MOUNTING DRIVERS SEAT QUESTION [Re: MR_P_BODY] #172086
12/21/08 10:31 AM
12/21/08 10:31 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Lots of good suggestions here...
First as Cab mentioned moving the seat as far rearward, and to the center will help with weight distribution. It also keeps you as far away from the door as possible, which is a good thing in case of a side impact.
Also, as Mr. P-body mentioned, the back angle of the seat has a lot to do with comfort. A lot of guys just slap it on the floor and call it good, but tilting the whole seat back will do a lot for comfort. Shoot between 21 and 23 degree's on the back angle and you should be good. That should put the cushion in the 10~15 degree spot (depending on how the seat was designed.)
Also, a lot of questions always come up about mounting the seat to the floor. This is a place where a lot of guys go over kill. If you think about the loads the seat see's during a crash they are really low. Your body weight really doesn't influence the seat during a frontal crash, because the seat is behind your body weight. Basically the seat attachment see's no more load with you in the seat, as it did without.
The factory to this day still just uses 4 attachment bolts to the floor. And most of the new seats have lap belts that attach to the seat itself not the floor. In a race car like ours, the seat belts go to the floor, we still have 4 attachment bolts, and you also attach the seat to the main hoop cross brace.
Just my
Re: MOUNTING DRIVERS SEAT QUESTION [Re: dizuster] #172087
12/21/08 01:26 PM
12/21/08 01:26 PM
Renton Washington
Triple Threat Offline
Renton Washington
FWIW, My car has your standard poly bucket seats and I've found out that they really need some back support to take the strain off the seat itself and the floor mounts. Mine actually cracked the floorboard after a couple years of racing it and the seat has more lean to it now than the passenger side seat.
I wouldn't recommend using them unless you have or are putting a roll bar in the car. Not enough internal strength in the seat\ to support a person.
Mount the seat wherever you feel most comfortable.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
