TBS A/W air flow? #172015
12/20/08 10:09 PM
12/20/08 10:09 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
i was wondering about any resistance and general air abillity of my cooler.the opening is 12.25"X 4" with about 1/2 being fluid tubes so about 24 sq inches of opening for airflow.
thanks for any help/info!
the opening on some blown intakes are hardly bigger that mine.
Re: TBS A/W air flow? [Re: blownzoom440] #172016
12/21/08 01:46 AM
12/21/08 01:46 AM
that is one of the itrems that need to be tested on a engine or chassis dyno on the same day under very control testing standards to find out if it is good, bad or indifferent. Do you have a air inlet temperature gauge? If so then you should be able to see it the inlet temps drop with it on versus with it off and do the dyno test to see if the cooler limits the total airflow into the motor enough to cause a loss of HP or not. Hard to tell from here how restrictive or non restritive it is I did some dyno testing at a dyno shop that did a A,B,A test on a super chiller brtand,if I remember correctly, and it ended up being a big blockage to airflow on a 355 C.I.SB Chevy using a 6:71 with two carbs on top, the pressure above the cooler went up and the pressures below stayed the same as before installing it Definent loss of HP on the dyno sheets, even with cooler inlet temps
Re: TBS A/W air flow? [Re: Cab_Burge] #172017
12/21/08 09:36 AM
12/21/08 09:36 AM
ELYRIA,OH
ELYRIA,OH
it wont be going back on the dyno but it did gain HP[125] with water in it.i am going only off total opening sq in.that is how BDS tests the effeciency of there builds blowing thru a X size opening to = X size enging.
here is a core pic.
