70 Challenger rocker molding install?? #17193
09/03/05 08:03 AM
09/03/05 08:03 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Can anyone give me a detail or pic or discription on 70 wide rocker molding installation? I need clip count and clip locations and if any screws are used. Thanks
Re: 70 Challenger rocker molding install?? [Re: Russ_Davis] #17194
09/03/05 03:48 PM
09/03/05 03:48 PM
Pittsfield, Mass.
Pittsfield, Mass.
Re: 70 Challenger rocker molding install?? [Re: Russ_Davis] #17195
09/03/05 04:28 PM
09/03/05 04:28 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
There are 6 clips per side on a '70.
Centerline is 1 3/4" from the top on the rocker and 3" from the bottom.
5/16" hole size.
The first hole is 6" on center from the front, and 5 additional holes spaced 9 1/2" apart on center after that.
The screw hole is 1/8", centerlined 4 1/16" from the bottom of the rocker and 2 1/2" measured from the front of the rear wheelwell.
Amazing how an unchallenged lie can become the absolute truth.
Re: 70 Challenger rocker molding install?? [Re: beepbeep] #17196
09/03/05 04:50 PM
09/03/05 04:50 PM
Pittsfield, Mass.
Pittsfield, Mass.
Thanks. Is there a hole and clip in the fender?
Re: 70 Challenger rocker molding install?? [Re: beepbeep] #17197
09/03/05 08:48 PM
09/03/05 08:48 PM
can a mod put this in the tech section
thanks beepbeep for posting this info
tom
Re: 70 Challenger rocker molding install?? #17198
09/14/05 11:06 AM
09/14/05 11:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
btt
