I've doubled the HP in my ShortBed #1718834
01/01/15 01:08 AM
01/01/15 01:08 AM
Back home in PA
BulletBob Offline OP
Back home in PA
With my decision to go GenIII Hemi in my RC & the trans going out in my ShortBed as well as the 318's gaskets dried out after sitting 5-6 years & was bleeding like a firing squad victim so
So it was out with this
& in with this
Behind it is a 727 now with a manual valvebody & the battery moves to the rear like the gas tank
The slam & a 8 3/4 with 3.91's is right after I finish up
Re: I've doubled the HP in my ShortBed [Re: BulletBob] #1718835
01/01/15 10:59 AM
01/01/15 10:59 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I likey! What manifold did you go with? And why the 2" spacer?
Re: I've doubled the HP in my ShortBed [Re: redraptor] #1718836
01/01/15 07:19 PM
01/01/15 07:19 PM
Back home in PA
Back home in PA
Edelbrock RPM so I could use the serpentine otherwise I'd have used a Crosswinds
A Holley carb won't clear easily at the A/C bracket
I'm using this 600 for now & when I get my 750 HP done I'll put it & the Whiplash to the Magnum
Re: I've doubled the HP in my ShortBed [Re: BulletBob] #1718837
01/02/15 04:04 AM
01/02/15 04:04 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Major upgrade.
Re: I've doubled the HP in my ShortBed [Re: BulletBob] #1718838
01/02/15 03:43 PM
01/02/15 03:43 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Major upgrade, My son pulled the 50HP (or whatever they were rated) 318 in his 88 and swapped in a 98 360. Truck is much more fun and usable now.
Sheldon
Re: I've doubled the HP in my ShortBed [Re: Magnum] #1718839
01/02/15 03:56 PM
01/02/15 03:56 PM
Back home in PA
Back home in PA
Major upgrade.
I did my CrewCab 8 years ago & put a 518 in with its Magnum
What a huge difference
It got better mpg than the truck it came from & the carb made that Magnum wake up some
I may put a 518 in this spring so I can take it on a trip or two
Re: I've doubled the HP in my ShortBed [Re: BulletBob] #1718840
01/02/15 04:20 PM
01/02/15 04:20 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Yes: Sean swapped out the 3 spd auto for an NV4500, another terrific upgrade.
Sheldon
Re: I've doubled the HP in my ShortBed [Re: RUNCHARGER] #1718841
01/02/15 04:55 PM
01/02/15 04:55 PM
Back home in PA
Back home in PA
Sheldon
One of my future swaps will be a NV upgrade with hydraulic clutch
Re: I've doubled the HP in my ShortBed [Re: BulletBob] #1718842
01/03/15 03:50 PM
01/03/15 03:50 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Oh. I figured you put a turbo efi /6 in it! Just kiddin......
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: I've doubled the HP in my ShortBed [Re: old_goat] #1718843
01/03/15 10:25 PM
01/03/15 10:25 PM
Back home in PA
Back home in PA
LOL Bill!
