what all is involved in lifting a wrangler 4-6 inches?
#1718610
12/31/14 04:29 PM
12/31/14 04:29 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
hey guys! i'm not usually over here on this thread but.... my son has decided he wants a wrangler late 90's to early 2000's. he likes the look of 'lifted' but would probably never do any type of off-roading. I have heard to stick with the straight six (4.0?) and stay away from the 4-bangers. I also don't know what all is involved in lifting a jeep. do you have to get new driveshafts? what about any wiring for say the speedometer? I thought I would ask here for some real world pointers before I start reading up on it. thanks!
Re: what all is involved in lifting a wrangler 4-6 inches?
[Re: DaytonaTurbo]
#1718612
12/31/14 05:35 PM
12/31/14 05:35 PM
mikemee1331
bethlehem pa
Search on ebay for jeep yj lift. He'll need new springs, shocks and a bunch of odds and ends. They sell it all in one kit. At around that lift level he may need a slip yoke eliminator to deal with the increased driveline angle. A 4" lift will need very big tires to not look stupid. Not cheap. Maybe better off with some 32" tires and a 1.25" body lift.
I thought 4-6 sounded too much without major changes. is 1.25 what is usually done to get that off-road look? I had a feeling most of the 'lift' was actually from larger tires but I haven't got any reference for it.
[Re: Golden-Arm]
#1718614
12/31/14 08:23 PM
12/31/14 08:23 PM
mikemee1331
bethlehem pa
forget the yj, get a tj. then, look up lift kit.
because of the coil springs or an aversion to square headlights? I kinda answered my own question about lifts by reading inspection codes. now i'm still curious about engines. I understand the straight 6's are easier to work on but what about the 4 cyl? are they just underpowered even with a manual?
[Re: mikemee1331]
#1718615
12/31/14 09:07 PM
12/31/14 09:07 PM
Posts: 8,160 Plymouth, MI
Blusmbl
Plymouth, MI
The 97-up TJ's are a lot more livable as a daily driver. They ride nicer and the interior is better.
If you want a YJ I believe the last couple years (94/95?) are the most desirable due to a better trans and engine. Think the external slave cylinder was 94/95. They switched from the 4.2 to the 4.0 with EFI in 1992. You also got the family style rollbar with rear seat shoulder belts in 1992 and up.
The 4 cylinder motor is reliable, it's just gutless. I've heard stories that the 4.0 will get better fuel economy in most situations.
4-6" of lift is a decent amount of work on either of them. For a smaller 2" lift I think you can get away with spacers on a TJ. You typically need about 4" of total lift on a TJ to get decently wide, 33" tires underneath it. You could accomplish that with a 2" coil spacer and 2" of body lift, or a complete suspension lift. On a YJ you have to swap springs.
[Re: Blusmbl]
#1718616
12/31/14 09:44 PM
12/31/14 09:44 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I would also recommend a TJ with 2" Suspension and 2" Body Lift....it will drive and ride much better that a 4" Lift Stay away from the 4-Banger unless you plan on a bone-stock Jeep with factory size tires. Rickster
[Re: rickstershemi]
#1718617
12/31/14 10:51 PM
12/31/14 10:51 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
If he is talking about late '90s to 2000s, then he is talking about a TJ to begin with. I ran a 3" Tera (S3T) back in the day, and thought it handled well. A good complete lift will include a t-case drop, as well as everything else you will need, including shocks, swaybay links and steering correction. If you are going to wheel it at all, I would suggest a heavy duty slip yoke eliminator (SYE) and double cardan driveshaft. At that point you can lift the t-case, and put a flat belly skid on it (with a 1 1/4" body lift {I make my own out of aluminum bar stock} and a motor mount lift) No wiring needed for the speedometer- it takes a standard MoPar speedometer pinion, just like my old Challenger R/T did. Just figure out the difference in tire size, and pick a pinion to match. BTW, stay away from the 4 cylinders if you are going to drive it on the street with anything bigger than stock tires. Bonus Pro Tip- A B-Body 8 3/4 makes a great rear end swap if you are running a D35, and will hold up to 35x14 Boggers or Q78 Swampers very well with a locker (even 38.5x11.00s if you're careful)
[Re: mikemee1331]
#1718621
01/01/15 12:05 PM
01/01/15 12:05 PM
Blusmbl
Plymouth, MI
Body lifts are just that... they lift the body away from the frame with longer bolts and pucks that go between the frame and body mounts. You usually will get extension pieces for the steering column, fan shroud and transfer case linkage depending on how complete the kit is. On pickup trucks a body lift will also relocate the bumpers upward.
[Re: mikemee1331]
#1718624
01/01/15 03:13 PM
01/01/15 03:13 PM
rickstershemi
I absolutely hear what you're saying DaytonaTurbo and since all he's looking for is the 'look' and not actually off-roading a lift under 2" is all we will need as long a we can get 32's or 33's under there to complete that image. I also agree that a 4 banger will be vastly under-powered with big tires.
My 2001 Sport fit 31's with no lift....I would think 33's with a 2" Lift would not be a problem...????
Rickster
[Re: Kern Dog]
#1718627
01/02/15 08:56 PM
01/02/15 08:56 PM
DaytonaTurbo
Manitoba, Canada
My local axle guy said that running any tire bigger than a 33" on these late model Jeeps results in rapid failure of the axles. He thinks they used thinner metal on the housings and they warp from the additional streeses from the bigger tires.
From what I've read on the forums, 34's or 36's are the limit for what the rear diff will take. IIRC the tj's had a better rear diff than the yj's.
[Re: Kern Dog]
#1718629
01/03/15 12:51 AM
01/03/15 12:51 AM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I have never seen the housings bad as far as warping. The smaller axle shafts are the weak links and the smaller gear set can be a weak spot. The 44 axle is for sure a lot stouter and more desirable. There are better axles for the 35 which help. Keep the tires at 33 inches will also help. I run a tall narrow tire 33 x 10.50 bfg on a 8 inch rim which gets harder to find. When you start with 33 x 12.50 on a ten inch with only 4 inches of backspace that works the axles hard.
[Re: NITROUSN]
#1718630
01/03/15 01:09 AM
01/03/15 01:09 AM
Posts: 5,336 the house on the left.
cogen80
We lift a lot of jeeps and I own one myself. I hate body lifts and with that being said here is my advice. 97 to 2006 TJ models ride and work real well with a lift. Your factory springs are most likely getting weak and not to OEM height anymore. So 4 new springs and shocks will do the job nicely. 3 to 4 inches will give you the best bang for your buck. Going over 4 inches will cost a lot more and you make a lot of durability and reliability compromises. I like BDS and Zone lifts. So 3 to 4 inch lift. Get a slip yoke eliminator and a cv rear shaft. That way the skid plate will stay stock height and you wont have to modify the 4wd linkage or have stiff shifting if a manual due to shift boot interference.
this is the best advise posted. listen to him. he is dead on.
i know a few guys running the 4 cyl. they have had good luck with them. just have to gear them.
[Re: Cooter]
#1718631
01/03/15 05:29 AM
01/03/15 05:29 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The 33" tire line is poppycock.
Okay, YOU know everything. I guess we should just PM you directly for every question from now on.
[Re: Kern Dog]
#1718632
01/03/15 07:03 PM
01/03/15 07:03 PM
mikemee1331
bethlehem pa
this site is the best and i'm glad to see this forum is no different than the other ones ! keep in mind that he wants the look but will never actually do any off-roading. that said here is what I've learned from here and a few other sites. either TJ or YJ is fine. i'm good with leaf spring suspension but the coil spring would be newer and probably more plentiful with the added plus of finding one that is just someones daily driver. straight six is what I should look for but a 4 banger might be ok for his use. 33's could present a problem with steering radius and might require a gear change but a 2 inch lift (not body) would be plenty. 31's are probably all he needs to achieve the 'look'. am I on track?
[Re: Kern Dog]
#1718633
01/03/15 08:36 PM
01/03/15 08:36 PM
Cooter
Chicagoland
Probably not everyone, but YOU might want to before you believe your "axle guy"
My photos are up there, those tires sure seem to be bigger than 33".
[Re: mikemee1331]
#1718634
01/03/15 08:40 PM
01/03/15 08:40 PM
Cooter
Chicagoland
He may not be satisfied with the look of 31" tires. But if he is, he can run them on a street driven TJ without a lift, as long as the springs aren't shot. With the correct back spacing, his steering radius shouldn't suffer.
[Re: mikemee1331]
#1718636
01/03/15 10:12 PM
01/03/15 10:12 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
yes, to both. get a rubicon tj, and be done with it.
the 4.0 is the engine to go with, along with the manual trans. the 4 cylinder is a slug. you'll burn more gas with it trying to roll larger tires, and you'll have no power. if you go with the 4, you'll soon want the 6. save yourself the aggravation.
just a quick skyjacker 4" lift kit. comes with everything, rolls on 33's with no problems. took a full day to install, in the driveway with no special tools.
[Re: QuickDodge]
#1718638
01/04/15 08:18 PM
01/04/15 08:18 PM
mikemee1331
bethlehem pa
No one has mentioned it, but it would depend on the OP's kid's maturity level as to whether or not the kid should have a 4 or 6 cylinder. Some teenagers should drive under powered vehicles!
very true! he's more into the 'sexiness' part than the tearing up the streets and yards part!
[Re: QuickDodge]
#1718640
01/05/15 01:13 AM
01/05/15 01:13 AM
DaytonaTurbo
Manitoba, Canada
Drive a lifted 6 banger jeep with big tires. A hot rod they are not. Even with stock tires...
