'74 W200 Drive Shaft replacement sources? #1718371
12/31/14 06:01 AM
12/31/14 06:01 AM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
The front D/S on the '74 W200 Power Wagon I bought last month has well worn, rusty and worn-out slip splines. The rear D/S, while much better seems fairly well worn too.
Is there some more affordable way to refurbish them than taking them to a D/S Repair shop? I was thinking about searching my local Pick A Part junkyard for potential replacements.
Any better ideas? I don't plan on spending $400 each or more to get them fixed except as a last resort.
On my Jeep, I once successfully cut up an old D/S and rewelded it to the correct length, keeping it in-phase and the balance was fine too.
Re: '74 W200 Drive Shaft replacement sources? [Re: D_C] #1718372
12/31/14 07:24 PM
12/31/14 07:24 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
