Re: Inboard leaf springs
[Re: mechanic190]
#1717971
12/30/14 08:09 PM
12/30/14 08:09 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
I have moved them them directly unnder the frame and then put the axle on top of the spring. This gave me enough room far a 14 X 32 drag slick without effecting the ride height. I used front spring hangers and rear shackel mounts from a B body lined them up to the outside of the frame rail and welded them in place.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1717972
12/30/14 08:14 PM
12/30/14 08:14 PM
W.I.N. Racing
Byron, NY
[Re: W.I.N. Racing]
#1717973
12/30/14 08:59 PM
12/30/14 08:59 PM
Posts: 1,788 Greer, SC
TooMany62s
Greer, SC
On my '84 I simply ground off the rivets holding the spring mounts to the frame. I welded a plate for mounting on the inside of the frame then swapped the springs side to side. I'm no chassis engineer but it was a pretty easy project. I'm using 31x18.50x15 rear tires with plenty of room after installing tubs. I used a narrowed rear from a car to move the springs under the axle.
