Ammeter Charging Question - Slight Charge Always
#1717519
12/29/14 10:33 PM
12/29/14 10:33 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Guys, I have noticed I always have a slight charging condition on my 1973 Charger when I am driving it. The ammeter of course pegs charging when you crank the car but then drops down to a slight charge and it stays there. By slight, I mean maybe 2-3 amps. Once the battery is topped off it doesn't matter if you are idling or running 3200RPMs on the highway, this charge is always there. Wiring is all stock reproduction and gauges were rebuilt by Instrument Specialties. The ammeter seems to be accurate as it is dead center when then car is off. Battery voltage is 14.6V at idle or when revving the motor. Is this normal? Could this be a battery issue? Or am I worrying over nothing? I am just curious if you guys have noticed this before on your cars. Thanks!
Re: Ammeter Charging Question - Slight Charge Always
[Re: cjskotni]
#1717520
12/30/14 12:33 AM
12/30/14 12:33 AM
Posts: 1,822 Colorado
denfireguy
Colorado
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1717521
12/30/14 01:13 AM
12/30/14 01:13 AM
Posts: 15,193 Omaha Ne
TJP
Omaha Ne
I'll politely disagree. A constant slight charge condition is indicative of a voltage drop somewhere between the Alternator, battery and IGN/ Accessory circuit which includes the Voltage regulator itself, grounds and a myriad of other gremlins. A kwik Voltmeter test will tell the story. IE: V at battery, V at alternator output, and voltage sense line to the VR. is it enough to worry about??? the difference between the Alt output and battery will answer that question
[Re: TJP]
#1717522
12/30/14 01:26 AM
12/30/14 01:26 AM
RapidRobert
Check the ground path(s) also on low (20 volt) scale. alt case to batt neg post/reg case to batt neg post (batt neg post is your reference point). As said break out your meter/check ALL terminals/connections. way less likely would be a batt cell going bad & subbing in another battery would ans that Q quickly. In almost all cases when an electronic reg goes bad it either goes open or full fields
[Re: RapidRobert]
#1717523
12/30/14 02:49 AM
12/30/14 02:49 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
1st question I'd do.
DO YOU HAVE SOME EXTRA DEVICE/ACCESORy hooked up to the batt side ? the load reading could be feeding that and not really a charging reading... which when revving up, batt also will demand the power lost when sourcing the acc, then the big charging reading
[Re: Mopar73340]
#1717526
12/30/14 09:41 AM
12/30/14 09:41 AM
cjskotni
North Carolina
Haha, I know so many people wire things incorrectly. The only non-stock load I have is electric fans and they (their relays) are powered from the alternator stud so when they run, the ammeter shows the proper readings. Everything else is powered from the factory locations.
I am 99.9% sure all my grounds are as good as it gets. I have ground jumpers run from the VR to the firewall tied to the ground strap that goes to the engine block. I would think if grounding were bad, the system would be charging at more than 14.6V.
The battery is a deep-cycle Interstate and is at least 5 years old. It appeared in the engine bay sometime during when my Charger was in body shop hell. I had it tested 2 years ago and it was fine they said (Advance Auto FWIW). Granted this car doesn't get driven more than 1-2x a week but maybe it is time for a new battery.
I'm glad to see I'm not the only one who has seen this. I am electrically proficient (I'd like to think) so I wanted to see if this was normal as I have eliminated the "easy" stuff already.
[Re: Supercuda]
#1717528
12/30/14 02:10 PM
12/30/14 02:10 PM
TJP
Omaha Ne
Wrong. Look at a schematic.
normal operating loads are on the alternator side of the ammeter. You will NEVER see them in the ammeter. If you are seeing a slight charge on the ammeter odds are it's one of two things, someone added a draw to the battery or the ammeter is off.
CORRECT!!!
The ammeter indicates current flow to and from the battery. A constant charge indication means the battery is constantly receiving current and potentially being overcharged. This could be due to a draw on the battery side of the circuit or voltage drops between the battery, alternator output and voltage regulator sense line. As designed the battery supplies current when the alternator is not sufficient due to low idle speed, high draw accessories, or when starting.
[Re: cjskotni]
#1717529
12/30/14 04:39 PM
12/30/14 04:39 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Read the owner's manual. "The alternator indicator pointer will normally stay centered while driving when the battery is fully charged and no lights or accessories are in use".
Note the reference to lights and accessories.
[Re: John_Kunkel]
#1717530
02/21/15 01:33 PM
02/21/15 01:33 PM
cjskotni
North Carolina
Well here is an update on this one. I noticed my starter has been getting slower and slower when I try to crank the car...even while cold. When the car was hot, it was a 50/50 chance it would crank fast enough to start! I also noticed that every so often if the car sat for more than a week, my radio would lose all it's settings. I got tired of this and checked the battery voltage after a 15 minute drive (and plenty of time to verify via ammeter that the battery was topped off) and battery voltage was only 12.18. I put a mutlimeter in series and verified current draw in only in the 9mA range so no significant parasitic draw really. I'm guessing my battery was going out! I have the new battery and I will holler back when I get it in and fire up the car!
[Re: DDodger]
#1717532
02/21/15 05:56 PM
02/21/15 05:56 PM
cjskotni
North Carolina
Yes the battery had run "wet". I suspect it was sulphated up pretty bad. Anyways I got the battery in and it fires right up like soooo easily now...even today when it was 25 degrees here. And...guess what...ammeter is DEAD center once the battery is topped off. My system is wired correctly, period. All loads are taken from the alternator side of the ammeter so it's honest. I check my charging voltage and it is closer to 14.9V which is higher than I'd like. I traced the voltage drop to the neg battery cable itself which read ~2.5 ohms. Everything else was 0 ohms. I appears my negative cable is coming apart a bit as I wiggled it good and it dropped back down. I guess I am ordering a new negative cable. The battery was the issue for sure. I didn't realize how fricken slow my starter had gotten.
[Re: cjskotni]
#1717534
02/21/15 08:36 PM
02/21/15 08:36 PM
Posts: 28 Montana
DDodger
Montana
That is ONE HELL of a lot of resistance if correct.
But don't try to shoot bad grounds and voltage drop with resistance, do so with voltage tests
Just picture in your mind the path that current takes. "th juice" going to the regulator comes off the battery, through the bulkhead and ammeter, through the ignition switch, harness, etc, back out the bulkhead and feeds to the regulator
There are a couple of places, there, namely the bulkhead connector, the ignition switch and the connector on the switch, that can create drop
Turn the key to "run" but with the engine not running
If you have breaker points ignition, make sure the points are closed, and make the test rapidly
Compare battery voltage to voltage feeding the regulator. On a 69 and earlier regulator check right at the regulator ignition terminal
On 70 and later this is harder. you can check at the blue field on the alternator. If you can get to the "key" side of the coil ballast, check there
What you are looking for here is the difference between battery and that point feeding the regulator. You want less, that is "zero" is perfect. If you come up with more than, say 3/10 of one volt, find out why.
Same with ground only this time, check with engine running fast enough to charge. Put your voltmeter on very low DC volts. Stick one lead to the battery NEG post. Stick the other lead to the regulator mounting, "the case." Here again, zero volts is perfect. Anything more than a 1/10 volt or so, you need to work on grounding.
Back to your neg cable. Here again, best way to check cables "bad" or not is under starting current loads. This is made easy with access to a "load tester." But you can "cheat" by just running the starter, ignition grounded. Check voltage across the cables during cranking.
[Re: DDodger]
#1717536
02/22/15 03:48 AM
02/22/15 03:48 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
The voltage from the battery leaves it on the negative side just like all batteries and returns through the positive side, the alternator charges from the alternator through the engine wiring harness to the bulkhead connector and then through the under dash wiring harness through the amp gauge and back through the same harness and then goes to the battery to keep it charged. Come on you guys, GET THE BASICS correct before intentionally or unintentionally misleading those that don't know D.C. current flow
[Re: Cab_Burge]
#1717537
02/22/15 06:02 AM
02/22/15 06:02 AM
Posts: 28 Montana
DDodger
Montana
you can take your two cents and you can go stick it somewhere
i simply IN SIMPLE TERMS described the CURRENT PATH. the PATH that the current takes, JUST ENOUGH of the description to ILLUSTRATE THE POINT which is the "direction" in which most people probably "think."
It matters not, oh engineering xpert, "which way" the current flows, and by the way, it wasn't all that long ago (in the 20's) when people believed there was "current" going from plus to minus.
I WAS ATTEMPTING TO ILLUSTRATE IN NOT TOO TECHNICAL TERMS how voltage drop occurs. The probability is, if someone is wondering what the drop is "doing" that they will be measuring and troubleshooting "from the positive end" of the system rather than the "ground" end. That is all I was trying to illustrate. THE WAY THAT VOLTAGE DROP HAPPENS
NOW I NOTICE that YOU the ENGINEERING XPERT "did not" attempt to illustrate anything helpful, anything factual, anything concrete. I notice that you made NO helpful contribution AT ALL.
You did not suggest, for example, that the voltage regulator must be held that is "grounded" very very close to the battery NEG and therefore to remove, clean, and retighten the VR mounting bolts. I notice you DID NOT suggest, as an example, to examine and to check the VR connector(s) and to be sure they are clean and tight. I further notice, as yet a further example, that you did not suggest how to functionally go through the checks for bulkhead, ignition switch, and it's related connector. I NOTICE that you did not SUGGEST ANY of this.
Don't you feel "helpful?"
"I'd bet money" I've been involved with things electrical and electronic longer than you. Statistically, it's "bettable."
