Issue with split monos #1716039
12/26/14 11:03 PM
12/26/14 11:03 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
We went to install our new splits today and ran into the following issue.
Both springs are twisted to the drivers side and im not sure what to do with them. Is there a trick to installing them ie. removing the clamps and then installing them which wouldn't make any sense to me as the segments would be out of alignment and the housing would be shifted over. Any help would be appreciated. thanks
Re: Issue with split monos [Re: nitrousr] #1716040
12/27/14 12:18 AM
12/27/14 12:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm pretty sure that's what's called "manufacturing tolerance". Loosen things up. install them, tighten things up. The variance at the juncture of the two segments will be minimal.
