Re: Help me finish my 470 for the Warlock
[Re: venom107]
#1713457
12/21/14 02:28 PM
12/21/14 02:28 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
MP 528 solid and the Eddy performer rpm.Will make a solid combo especially with the 1.6 rockers.The 850 will be fine.
[Re: venom107]
#1713458
12/21/14 02:41 PM
12/21/14 02:41 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Those 1.6 rockers are going to speed up whatever cam you choose.Is a hyd cam an option? Hyd roller would be a nice choice.I might check the Lunati catalog.Everything else is fine.IMO 470 is probably the most efficient of the strokers.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#1713460
12/21/14 07:03 PM
12/21/14 07:03 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I used the 296*/.557 Mopar solid cam with 1.5 Sig Erson rockers in a bracket 440 I built 30 years ago. It was mostly stock, "906" heads, 2.08 x 1.74 valves, no porting or blueprinting, heavy TRW 10.5 pistons, 6-pack rods, stock balance, single plane intake and a borrowed 850 DP. That cam was very civilized in that combo. You could go a lot bigger in a bigger motor and be just as civilized. My new blueprinted 440 has a Comp hydraulic cam with more lift and duration with 1.6 adjustable rockers. Not that I am lazy, but I don't want to be adjusting a solid cam anymore. This is my hobby, not my obsession
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: mike s]
#1713461
12/21/14 09:16 PM
12/21/14 09:16 PM
Posts: 65 Huntsville, AL
venom107
Huntsville, AL
Mike, I have considered hyd roller, that was my initial plan, but for everyone that thought is was a good idea, I would have 5 that would tell me to stay away (cost, reliability, RPM). I'm still not opposed to the idea, for my initial reason, wiping a lobe. Wipe a lobe and you end up spending what a hyd roller would have cost, if not more.
The Lunati 294/302 looks to be the closest to the numbers I have been considering, but would likely be pushing the limits of the springs I have with the 1.6 rockers. Crane has some good looking numbers, but they are proud of them.
[Re: venom107]
#1713464
12/30/14 06:39 PM
12/30/14 06:39 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
With 3.55 gears I would call comp cams. You want torque to move that truck. And also build enough vacuum to be happy driving it.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
