Help me finish my 470 for the Warlock #1713454
12/21/14 02:10 AM
12/21/14 02:10 AM
Huntsville, AL
V
venom107 Offline OP
venom107  Offline OP
V
Huntsville, AL
Here is what I have.
78 Warlock, 727, 8 3/4 3.55, mini tubbed, running 295/40/18 on the street.
1972 400 block (short block assembled and zero decked)
3.90 stroke crank
H beam rods
CP flat tops
Stealth heads (bowl blended and cleaned up)
Comp 26120 beehive springs with retainers and 10 deg locks
Crane gold 1.6 rockers
Cam? Thinking MP .557 (not looking for aggressive ramp cam, This will be mostly street driven with occasional track days)
Intake? RPM or Victor/M1
Carb? I will start with an 850DP I have hanging on the wall.
I will have a converter built after I see what it will do on a dyno.
So let's hear some comments cam, intake and carb.
Re: Help me finish my 470 for the Warlock [Re: venom107] #1713455
12/21/14 04:26 AM
12/21/14 04:26 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Exh sys? Comp ratio?
Leave the gun.......take the Cannoli's....Mike
Re: Help me finish my 470 for the Warlock [Re: mike s] #1713456
12/21/14 11:42 AM
12/21/14 11:42 AM
Huntsville, AL
V
venom107 Offline OP
venom107  Offline OP
V
Huntsville, AL
Comp should be just about 11-1. Exhaust currently is block hugger shorties with 2.5 all the way out, running Thrush muffs. Exhaust subject to change down the road, but it is what I will start with.
Re: Help me finish my 470 for the Warlock [Re: venom107] #1713457
12/21/14 02:28 PM
12/21/14 02:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
MP 528 solid and the Eddy performer rpm.Will make a solid combo especially with the 1.6 rockers.The 850 will be fine.
Nautilus Racing-
Re: Help me finish my 470 for the Warlock [Re: venom107] #1713458
12/21/14 02:41 PM
12/21/14 02:41 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Those 1.6 rockers are going to speed up whatever cam you choose.Is a hyd cam an option? Hyd roller would be a nice choice.I might check the Lunati catalog.Everything else is fine.IMO 470 is probably the most efficient of the strokers.
Re: Help me finish my 470 for the Warlock [Re: mike s] #1713459
12/21/14 03:45 PM
12/21/14 03:45 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
I am going to follow this, have a 400 close ratio 4 speed I would love to do something with.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Help me finish my 470 for the Warlock [Re: mike s] #1713460
12/21/14 07:03 PM
12/21/14 07:03 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I used the 296*/.557 Mopar solid cam with 1.5 Sig Erson rockers in a bracket 440 I built 30 years ago. It was mostly stock, "906" heads, 2.08 x 1.74 valves, no porting or blueprinting, heavy TRW 10.5 pistons, 6-pack rods, stock balance, single plane intake and a borrowed 850 DP. That cam was very civilized in that combo. You could go a lot bigger in a bigger motor and be just as civilized.
My new blueprinted 440 has a Comp hydraulic cam with more lift and duration with 1.6 adjustable
rockers. Not that I am lazy, but I don't want to be adjusting a solid cam anymore. This is my hobby, not my obsession
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Help me finish my 470 for the Warlock [Re: mike s] #1713461
12/21/14 09:16 PM
12/21/14 09:16 PM
Huntsville, AL
V
venom107 Offline OP
venom107  Offline OP
V
Huntsville, AL
Mike, I have considered hyd roller, that was my initial plan, but for everyone that thought is was a good idea, I would have 5 that would tell me to stay away (cost, reliability, RPM). I'm still not opposed to the idea, for my initial reason, wiping a lobe. Wipe a lobe and you end up spending what a hyd roller would have cost, if not more.
The Lunati 294/302 looks to be the closest to the numbers I have been considering, but would likely be pushing the limits of the springs I have with the 1.6 rockers. Crane has some good looking numbers, but they are proud of them.
Re: Help me finish my 470 for the Warlock [Re: venom107] #1713462
12/21/14 09:45 PM
12/21/14 09:45 PM
IN
ahy Offline
ahy  Offline
IN
I think the RPM intake would provide more mid-range and fit your application best. Either the 528 or 557 MP cam should do fine... its a matter of "personality". Both have pretty long duration but the 528 should have better manners than the 557 and maybe a bit better fuel consumption if that matters.
It sounds like you will have perfect "quench" with zero deck... even so 11:1 may be pushing it on pump premium. The bigger cam may resist detonation better.
I personally like solid flat tappet's... make sure lifters are free to spin, assembly lube well, start up fast and run high zinc oil and there should be no problems.
Re: Help me finish my 470 for the Warlock [Re: ahy] #1713463
12/24/14 01:26 AM
12/24/14 01:26 AM
Huntsville, AL
V
venom107 Offline OP
venom107  Offline OP
V
Huntsville, AL
Got me considering following close to this build.
http://www.hotrod.com/how-to/engine/1007phr-big-block-mopar-engines/
I will be down 35 ci and around 11-1, but most of the rest would be very similar.
Re: Help me finish my 470 for the Warlock [Re: venom107] #1713464
12/30/14 06:39 PM
12/30/14 06:39 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
With 3.55 gears I would call comp cams. You want torque to move that truck. And also build enough vacuum to be happy driving it.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Help me finish my 470 for the Warlock [Re: EV2CUDA] #1713465
03/05/15 01:44 PM
03/05/15 01:44 PM
Huntsville, AL
V
venom107 Offline OP
venom107  Offline OP
V
Huntsville, AL
I have had a couple of things come up that have kept me from working on this project, but it looks like it's time to get back on it. I am however, still stuck on cam selection. I am currently considering the MP .557 or going hyd roller with something like Comp XR292HR. Just having a hard time pulling the trigger either way.
