SQUEAK.SQUEAK.SQUEAK. New Leaf Springs...
#1713118
12/20/14 01:11 PM
12/20/14 01:11 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
I installed new leaf springs and as you can surmise by the Subject Line - I'm experiencing squeaky noises. Bumps, backing, turning, etc... To drowned out the leaf spring squeaky noises, I've thought of putting two styrofoam coolers in the back seat and let them rub together - at least I KNOW how to fix THAT noise. Any suggestions on how to fix?
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: SQUEAK.SQUEAK.SQUEAK. New Leaf Springs...
[Re: TJP]
#1713121
12/20/14 03:01 PM
12/20/14 03:01 PM
Posts: 4,703 Florida
BDW
[Re: BDW]
#1713122
12/20/14 03:44 PM
12/20/14 03:44 PM
WyleECoyote
Tennessee
Did you change the hangers too?
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
No, I did not change the hangers. This is on my 72 Imperial. I bought new springs from Spring's N' Things - and just swapped them out. THANKS for the link! I'll get up under there and check for any fresh metal-to-metal marks.
[Re: WyleECoyote]
#1713125
12/21/14 01:59 AM
12/21/14 01:59 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
I think on mind I sprayed around under there with some silicon lube.
68 Roadrunner. 383 4-spd. Beat up.
[Re: ahy]
#1713127
12/21/14 12:11 PM
12/21/14 12:11 PM
WyleECoyote
Tennessee
Besides the bushings, excess U bolt torque can cause squeaks. Had that problem myself after assembling MP XHD springs.
Required torque is pretty low, 45 ft lb from memory. Too much will bind up the spring and case squeaks. Loosen and re-torque fixed mine.
Thanks AHY - I had no idea. And coincidently, the guys around the garage call me "Ted Torque" because I'm always pushing that ratchet like nobodies business when I'm tightening things up. This could very easily be a contributing factor to my squeaking! Thanks!
[Re: screamindriver]
#1713129
12/21/14 09:26 PM
12/21/14 09:26 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
Speaking of the Mopar leaf springs, I have some of the OE plastic tip pads (with the shorty barrel clips), as well as some of the leaf spring bands with clear zinc finish. I used to supply & produce these bands to Year One for years - just quit doing these for them about a year ago. PM me if you need any of these parts.
[Re: Sunroofcuda]
#2738527
01/31/20 09:51 PM
01/31/20 09:51 PM
WyleECoyote
Tennessee
I started driving the car again; ha ha! A little 5 year pause. Still squeaking! Anyone learn anything since then??
[Re: CMcAllister]
#2738607
02/01/20 07:06 AM
02/01/20 07:06 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Someone else that uses JB80 penetrating spray. I have been using JB80 in my shop for over 20 years. Best stuff that I have found for rusted bolts, rusted bleeders, anything rusted fast, squeaky and sticking parts. Not cheap , but it works great.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
