I need some education/advice on 72-93 4x4 steering
#1712743
12/19/14 02:15 PM
12/19/14 02:15 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I need a bit of education here on the steering differences between the early and late 72-93 trucks. I have a 73 W200 that has the original reverse rotation steering gearbox that mounts to the 90 degree adapter with a linkage going to the steering arm on the axle. The existing axle is the original drum brake 8-lug D44 and there is a 4 inch steering lift block on the axle. From my understanding the reverse rotation steering only lasted until sometime in the mid 70's. I also have a front Dana 60 axle from a 1989 or 1990 W-350 which I would like to swap into the truck for the added durability but also for the much better brakes. If I understand it correctly the Dana 60 should be set up for the normal late style frame mounted steering gearbox. The truck is lifted about 5 inches on 35 inch tires. Can I keep the original reverse rotation steering and just add a steering lift block to the D60? If so, would I be able to use the existing steering arm, or would that be wrong for the reverse rotation? Or would I be better off switching to the later style box and using crossover steering and getting rid of lift blocks altogether? If I switch to the later style of steering does it use the holes that are already in the frame for the 90' bracket? I'd probably use a kit like the one from ORD . Either way I go I need a new steering gearbox as the current one is really loose and needs a rebuild. Any advice is appreciated! -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: I need some education/advice on 72-93 4x4 steering
[Re: blown340]
#1712744
12/19/14 02:15 PM
12/19/14 02:15 PM
blown340
Walnut Creek, CA
Here is the Dana 60 ready for its freshening.
[Re: blown340]
#1712745
12/19/14 02:16 PM
12/19/14 02:16 PM
blown340
Walnut Creek, CA
Existing reverse rotation gearbox
[Re: blown340]
#1712746
12/19/14 02:17 PM
12/19/14 02:17 PM
blown340
Walnut Creek, CA
Existing steering arm on the D44 with a lift block under the arm.
[Re: blown340]
#1712747
12/19/14 02:17 PM
12/19/14 02:17 PM
blown340
Walnut Creek, CA
And for no particular reason, the truck.
[Re: blown340]
#1712748
12/19/14 03:49 PM
12/19/14 03:49 PM
Posts: 5,748 ohio
ruderunner
ohio
D60 fits right in, no problem with the steering. Yes you will need the D60 steering block. Note the 60 uses differe not spring plates due to the larger axle tubes.
Angry white pureblood male
[Re: Jeremiah]
#1712750
12/20/14 12:07 AM
12/20/14 12:07 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
My 73 W200 has the Saginaw 808 P/S box on the 90* mount. Great idea that they should have stayed with. With 33" tires I've 4 wheeled the heck out it with no frame cracking problems. I have 4" Skyjacker springs with a raised steering arm. Seem a many Chevys with the same 808 box and no 90* mount with major cracks in their frames.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: savoy64]
#1712752
12/20/14 12:10 AM
12/20/14 12:10 AM
moparmarks
You could always convert your 73 Dana 44 to Chevy 12" disc brakes. Did mine back in the late 80's. The Chevy spindles bolt up to the Dodge knuckle and use the Chevy outer axle shafts. Real easy conversion and makes a ton of difference. Just find and early 70's Chevy C20 4x4 with the Dana 44. Also increases the front track by 3"
[Re: moparmarks]
#1712753
12/20/14 11:07 PM
12/20/14 11:07 PM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
One item to take note of in a Chevrolet knuckle conversion is caliper interference on a 15" rim. 16" will clear without issue however grinding on the caliper body will me mandatory to fit a 15 wheel.
[Re: Jeremiah]
#1712754
12/20/14 11:26 PM
12/20/14 11:26 PM
moparmarks
Not really an issue on a W200 which is 8 lug usually have 16" wheels
[Re: moparmarks]
#1712755
12/21/14 11:36 PM
12/21/14 11:36 PM
Jeremiah
Rogue River, OR
Do you hear an echo? It is an issue with 15" wheels and they clear fine with 16" wheels My W150 had 15" wheels and I converted it from half ton to 3/4 ton axles. Lots of rubbing until we did lots of grinding lol.
[Re: Jeremiah]
#1712756
12/22/14 02:16 AM
12/22/14 02:16 AM
moparmarks
More like voices. Where do you get 15" 8-lug wheels and why? OP has a W200.
[Re: moparmarks]
#1712757
12/23/14 03:41 AM
12/23/14 03:41 AM
blown340
Walnut Creek, CA
Thanks for the feedback everyone. I think I'm leaning toward keeping the original reverse rotation steering and replacing the gearbox and using a steering lift block on the D60. The one question I still have is the steering arms on each axle. The arm on the original D44 is shaped quite a bit differently than the one on the D60 and appears to be shorter as well, but I need to go measure. Does anyone know if there are any issues with using the late D60 arm in conjunction with the original reverse rotation steering other than possibly the size of the tie rods? Thanks for the recommendations on updating the D44 above, but the swap to the D60 is locked in. The D44 is pretty worn out and since that picture of the D60 was taken a while back I've gone through it entirely with new seals, bearings, hub work, etc.. Thanks! -Jon
