First Stock Voltmeters in Dodge Trucks?? #1712646
12/19/14 04:31 AM
12/19/14 04:31 AM
Graham, WA
P
Polarapete Offline OP
P
Graham, WA
I need to update the instrument cluster on my'87 D100 and would like to replace the inoperative ammeter with a voltmeter. When was the Voltmeter available in the truck line so I know what to look for? I would be willing to replace all the gauges to get the right look. Thanks for any help.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: First Stock Voltmeters in Dodge Trucks?? [Re: Polarapete] #1712647
12/19/14 08:34 AM
12/19/14 08:34 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You will also have to bypass the wiring and only get a low amp under the dash so you don't burn up the harness. Do a search on here that discusses the wiring issues.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: First Stock Voltmeters in Dodge Trucks?? [Re: Polarapete] #1712648
12/20/14 06:55 PM
12/20/14 06:55 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I've got an OE voltmeter in my '87 D250 BUT...it came with a complete cluster from a 1992 D250 and I think all the gauges are driven by the computer. It was all part of the conversion to 5.2 Magnum, A518, and the complete cooling, heat/AC and wiring systems. It looks stock, using the original gauge bezel but now it has a 'Check Engine' light and other such stuff. I don't know if the voltmeter could be installed in the earlier cluster or used without the computer.
