valve stem replacement #1712495
12/18/14 07:40 PM
12/18/14 07:40 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
I have a 2014 Dodge Ram Sport 1500... The left front tire will not take air. Something is wrong with the valve. I know these are the remoting sensor type, but can the actual valve be replaced like the old-school valves could be with the special screwdriver to unscrew the internal valve and replace it with a new one? Or, does one have to replace the complete valve sensor?
Thanks..
Troy
Troy
Houston Mopar Connection Club
Re: valve stem replacement [Re: hemi68charger] #1712496
12/18/14 08:59 PM
12/18/14 08:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is that not covered by warranty?
Re: valve stem replacement [Re: hemi68charger] #1712497
12/18/14 09:10 PM
12/18/14 09:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The core should come out.
Re: valve stem replacement [Re: hemi68charger] #1712498
12/18/14 09:38 PM
12/18/14 09:38 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
if the schrader portion is leaking, it replaces just like any other insert. if the tpms is bad, the warranty should cover replacement, and it too is easily replaced, from the inside of the wheel.
Re: valve stem replacement [Re: Golden-Arm] #1712499
12/18/14 11:01 PM
12/18/14 11:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The valve is a normal rubber stem. The tpms sensor attaches to it with a screw. The stem works the same with or without the sensor attached.
Re: valve stem replacement [Re: NITROUSN] #1712500
12/19/14 12:35 AM
12/19/14 12:35 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Is your valve stem metal or is it rubber? 2014 should be rubber but dodge metal screw in type tpms had bad corrosion issues
Re: valve stem replacement [Re: 72d100] #1712501
12/19/14 11:49 AM
12/19/14 11:49 AM
Houston, Tx
Houston, Tx
Thanks all.
It is still under warranty ( I have the lifetime warranty ). But, like any warranty at a dealership, there's a lot of time wasted trying to get it in. If I can replace the valve easily enough for a wee amount, then I'm willing to do that..
Troy
