Re: Indy or Mopar performance 4150 Intake
[Re: Dan Brewer]
#171204
12/20/08 12:42 PM
12/20/08 12:42 PM
Posts: 3,504 DFW
mr_340
DFW
Thanks to Andy for getting MP to reintroduce this intake. I've looked at it for several years but thought it was for Stage VI heads. MPs description really didn't give enough information to know what the application was for. Here is the PDF file for the intake from the Mopar website.
Floyd Lippencott IV
[Re: AndyF]
#171209
12/20/08 06:03 PM
12/20/08 06:03 PM
you can use the indy intake,just cut the tops off the factory valley pan (steel bathtub intake gasket) and run a paper intake gasket on top and bottom,i have done this many times,works perfect.
[Re: Dan Brewer]
#171214
12/22/08 10:15 AM
12/22/08 10:15 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Has anybody run the 337 with the victor heads and how are the inner intake bolt locations?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: AndyF]
#171216
12/22/08 11:11 AM
12/22/08 11:11 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I don't know why Mopar Performance hasn't done a little better job promoting this intake.
All fixed for the '09 catalog, vague statements removed, accurate description given, etc.
There are 5 in the Warren depot, so availability is decent also.
[Re: 65 Hemi]
#171217
12/22/08 01:40 PM
12/22/08 01:40 PM
Posts: 30,994 Oregon
AndyF
Here is a thread on this intake. (maybe should be in the archives?) https://board.moparts.org/ubbthreads/show...part=1&vc=1
The inner intake bolt locations are fine, easy to get a full length bolt in there and room for a wrench.
