5.9 Whiplash Cam users.... #1710412
12/14/14 02:02 PM
12/14/14 02:02 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Did you use your stock pushrods? I recently threw this stick in my stock 5.9. Torqued the rockers down and they are pretty loose. Could this be a symptom of the lifters not being pumped up (My first roller motor, I don't even know if they pump up) or am I in need of longer push rods? Thank you guys.
Re: 5.9 Whiplash Cam users.... [Re: midnite360] #1710413
12/14/14 05:07 PM
12/14/14 05:07 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I did use stock pushrods, but, stock heads were also shaved .030, and stock gaskets were replaced with fel-pros. between the 2, I took out .050" of required pushrod length.
Now that I have edelbrock heads on the motor, I have adjustable roller rockers
If you're loose, You probably need longer pushrods. stock cam has like, .420 lift? that 5.9 whiplash has .544 lift.
**Photobucket sucks**
Re: 5.9 Whiplash Cam users.... [Re: 70Cuda383] #1710414
12/15/14 11:52 AM
12/15/14 11:52 AM
scratchnfotraction Offline
it should fit in a stock 5.9 magnum with only a spring change on the heads.
the 1.6 rocker ratio is what makes it have more lift in the magnum engine.
my pre-mag LA 318 with #302 heads got .485/.487 lift with 1.5 rocker ratio.
stock roller valve gear with comp 901-16 springs.
some of them will feel loose untill you run it and get oil pumping thru them.
mine are all used roller lifters that I have cleaned and inspected. they always take about 20 mins or so of idle run time to get the air pumped out when they are empty.
I spin mine over a good bit with the plugs out before fireing it off getting oil psi showing on the gauge.
I got 3 of the whiplash cams 2 in LA engines and 1 440 flat tappet and orderd up another roller for the w350 4x4 I just brought home.
I love the whiplash cams.
Re: 5.9 Whiplash Cam users.... [Re: scratchnfotraction] #1710415
12/15/14 12:56 PM
12/15/14 12:56 PM
Goodyear Arizona
Goodyear Arizona
Thank you for the Input guys, going to end up calling Hughes to get their input as well. I plan on spinning that oil pump a good bit before starting for sure....motor is dry as can be. Can't wait to hear this junkyard monster I have created! LOL
Re: 5.9 Whiplash Cam users.... [Re: midnite360] #1710416
12/15/14 01:18 PM
12/15/14 01:18 PM
JY whiplash engines are us
I just scored a 5.2 magnum engine with 98,000 miles from a 93 DAK for my new to me 82 w350 4x4 flatbed.
Re: 5.9 Whiplash Cam users.... [Re: scratchnfotraction] #1710417
12/15/14 08:36 PM
12/15/14 08:36 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i still have the shelby motor for ya, when i finish putting together the new 340.
Re: 5.9 Whiplash Cam users.... [Re: Golden-Arm] #1710418
12/15/14 09:32 PM
12/15/14 09:32 PM
you bet! just say when.
the 89-360 headed 318 police engine I scored from member LARRY360 just got a new whiplash roller installed. wont be long and the 91-318 will have 200,000 on it and get swaped out for the police engine on the NV4500
I will slide the Shelby engine into the 94 Ram on the NV3500
I think I will go pick up that 69 440 for 300$ next week while I am stocking up on spare engines.
Re: 5.9 Whiplash Cam users.... [Re: scratchnfotraction] #1710419
12/16/14 03:14 PM
12/16/14 03:14 PM
dogdays Offline
dogdays  Offline
My motto: A man can never have too many pieces of cast iron aging in his back yard.
R.
