Re: Schumacher 5.7/6.1 Gen 3 to BEC Mounts
[Re: Jerry]
#1709600
12/19/14 03:34 PM
12/19/14 03:34 PM
Posts: 2,432 NorCal
RylisPro
NorCal
-10 even though technically 5/8 line has about 1/2 id. I would consider using -12 minimum
Yeah I'm going to switch over to -12AN The Derale oil adapter 72Swinger recommended is on backorder but I found this Haburger's 3320 instead
It has -12AN ports
I'm not sure how a thread about mounts became about oil plumbing haha! I'm going to start another new thread on that also
[Re: RylisPro]
#1709601
12/24/14 11:21 PM
12/24/14 11:21 PM
Posts: 2,432 NorCal
RylisPro
NorCal
[Re: 72Swinger]
#1709603
12/25/14 12:32 PM
12/25/14 12:32 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Those look familiar lol!
But about $150 cheaper. But I have a feeling mine would probably look the same in time. Can't see myself blowing another $200 on a pair of mounts yet with a simple round bushing in them.
The powder coated ones do look sharp btw.
[Re: BigBlockMopar]
#1709604
12/25/14 01:50 PM
12/25/14 01:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Why doesn't someone make a mount that bolts to the GenIII and replicates the location of the ears on an LA block. Then you can just use whatever LA setup fits your body.
Same adapter mount for a 65 Cuda, 87 Diplomat, 92 Ram, etc instead of all this monkey works they have today.
nah, be too obvious and simple. Couldn't charge a buttload of cash for it.
[Re: Supercuda]
#1709605
12/25/14 04:05 PM
12/25/14 04:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Because factory mounts suck, most Gen III would turn a factory mount to hamburger. Another problem is the way the acc are on a Gen III, using a factory configuration means you lose A/C and your factory oil filter location. Then the other alternative is a truck front cover with acc up high, what comes with that is you have to run a truck intake or a carb style intake because a car EFI factory intake will hit the truck cover. It sucks, that's why I went my own route, I looked at all this and everything had "extra fab work" written all over it. So I fabbed my own and removed the drivers engine mount tower off of my K member completely. That way in the future I can run a OEM size A/C compressor in the factory 6.1 location and only need a longer belt. I have to thank Wade and a few other guys for diving in ahead of me and showing me the hurdles they had to jump over on their own cars. That saved me ALOT of cuss words.
Mopar to the bone!!!
[Re: RylisPro]
#2384927
10/10/17 04:42 AM
10/10/17 04:42 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Quick update on the Schumacher mounts. They are still doing great but I noticed that the driver side bolt that goes through the polyurethane bushing had loosened up over time due to vibration and slid back, luckily it stopped at the header and didn't fall off. My fault for not checking periodically. I had last checked it last year and never since but will now make it another routine check before going on a track day. Good news is that the bolt is long enough that one can easily add a metal lock nut to prevent this issue. I'm also going to call Schumacher an notify them of my findings
