Re: oil pan site window
[Re: MR_P_BODY]
#1708033
12/08/14 01:04 AM
12/08/14 01:04 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
What type of hose can I use that will be ok with the heat and oil.good to see you back Mr.P
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1708036
12/08/14 01:39 AM
12/08/14 01:39 AM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
I just used some clear plastic hose from the hardware store, and a couple of brass elbows. One end of each elbow had a hose barb. The other end just had a thread, which I brazed to the pan.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: WHITEDART]
#1708039
12/08/14 12:05 PM
12/08/14 12:05 PM
Hemi_Joel
Minnesota
Here's another thing that is nice about having a sight tube: You can see how much the oil level drops when the engine is running. I had someone rev the engine while I watched the tube. It got scary low. As a result, I added another quart.
