440 rv turbo kit #1707048
12/05/14 10:55 PM
12/05/14 10:55 PM
Kelowna bc canada
Short box Offline OP
Kelowna bc canada
I recently came across a pic/ article about a rv single turbo set up for big block motorhomes and obviously wanted one for the 88 shortbox im doing, has anyone found or know of any forsale??? any leads or info would be great!
thanks
2005 regular cab short box Daytona 1988 regular cab short box D100
Re: 440 rv turbo kit [Re: Short box] #1707049
12/06/14 01:17 AM
12/06/14 01:17 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What are you building the truck for? Street rod or tow rig? If a tow rig, imo you'd be better off with some upgraded pistons than a turbo. The 440 should already have ample torq for towing. A decent compression ratio would help get the efficiency up.
Re: 440 rv turbo kit [Re: DaytonaTurbo] #1707050
12/06/14 06:36 PM
12/06/14 06:36 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
The only thing worth using is the exhaust manifold with a big turbo and blow through setup.
That is my plan, but not for towing. I found a rv turbo exhaust manifold on ebay oem never used for $300.
It has a t4 flange.
Parts from this kit don't come up as often as they used to.
