cummins quit moving?
#1706680
12/04/14 08:45 PM
12/04/14 08:45 PM
Posts: 954 garnett kansas
rhad
garnett kansas
my buddy has a 95 cummins 4x4 manual trans truck,308,000 miles,has been very dependable,he was goin down the road today and it just stopped pulling,engine runs fine,no matter what gear its in or the t case is in just nothing!!,we are going to take a looksee tomorrow,just wondering what the most likely culpert is?,5th gear was fixed some yrs back! thanks in advance!!
my ladder of success is missing some rungs
Re: cummins quit moving?
[Re: rhad]
#1706681
12/04/14 09:23 PM
12/04/14 09:23 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have seen a couple input shafts snap on the earlier nv4500.
[Re: HotRodDave]
#1706682
12/04/14 10:30 PM
12/04/14 10:30 PM
rhad
garnett kansas
i see there are upgraded shafts that are larger in diameter,i presume that means you have to change out the clutch disc?
[Re: rhad]
#1706683
12/05/14 12:21 AM
12/05/14 12:21 AM
Posts: 3,265 Pyeongtaek, South Korea
69HemiGTX
Yes. You have to use the 13" NV5600 clutch with the 1 3/8" input. Consequently, you must also modify or replace your flywheel for the larger clutch.
OIF V and OEF X veteran and proud of it!
[Re: dusturbd340W5]
#1706686
12/06/14 02:59 AM
12/06/14 02:59 AM
rhad
garnett kansas
im thinking either the input shaft of the center is out of the clutch disc,owner thinks the easiest way to tell is remove the pto cover start engine in neutral and see if the gears turn,maybe tomorrow will tell i see input shafts for as cheap as $100,dont think id trust one that cheap
[Re: rhad]
#1706687
12/06/14 07:29 PM
12/06/14 07:29 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it just stopped pulling while cruising (not pulling hard) I'd be more inclined to think pump failure.
Install a pressure gauge on the line pressure test port or disconnect a cooler line and check for fluid flow in Neutral.
[Re: HotRodDave]
#1706689
12/06/14 10:41 PM
12/06/14 10:41 PM
rhad
garnett kansas
pulled off the pto cover and started truck in gear,nothing turning,so input shaft(my vote),or clutch disc,308,000 on it,he is thinking of selling as is?
[Re: RUNCHARGER]
#1706691
12/07/14 12:23 AM
12/07/14 12:23 AM
rhad
garnett kansas
i see some input shafts for less than $100,can they be worth installing?
[Re: rhad]
#1706692
12/07/14 12:59 AM
12/07/14 12:59 AM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Why? The truck has gone a bazzilion miles on whats there now. Drop the tranny see whats broke. If its just a clutch upgrade to a south bend and get it back on the road.
[Re: dusturbd340W5]
#1706693
12/07/14 09:43 AM
12/07/14 09:43 AM
Quicktree
check the pre filter and lift pump, along with fuel shut off. just went through this crap
Tony go get your glasses, he stated the engine runs fine.
i related the quit moving as not running
[Re: Quicktree]
#1706694
12/11/14 07:30 PM
12/11/14 07:30 PM
rhad
garnett kansas
we got it apart today,the center is out of the clutch disc because the pilot bearing is missing in action!!,at least most of it
[Re: savoy64]
#1706696
12/12/14 02:32 AM
12/12/14 02:32 AM
rhad
garnett kansas
the pilot shaft is worn down some but he says he is gonna put it back together like that with a new pilot bearing,how long will it last?,how long did it last the first time,its a 95 with 308000 on it
[Re: savoy64]
#1706698
12/12/14 10:07 PM
12/12/14 10:07 PM
rhad
garnett kansas
now he decided to replace the input shaft,who has one for sale that is NOT chinese,im told some are made in india,i like the sound of that better,whats the best deal,ebay ,or??
[Re: savoy64]
#1706699
12/14/14 03:24 AM
12/14/14 03:24 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
most i have seen the clutches were out and you dont know when the bearing gave up---but i have pulled a couple junkyard nv4500,s and dont know how many miles were on it and they also had bad pilot bearings----made me wonder if the solid brass ones are better----you would think a person in a cummins shop would have a good idea of how long those little pilot bearings last.....
The pilot bearing in my gasser rig with an NV4500 broke down and the needle bearings got swedged so bad to the input shaft that the clutch would not disengage. It was all rusty and dry as if it was never greased when new!
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
