Page 4 of 4 1 2 3 4
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #1705802
03/13/15 11:29 AM
03/13/15 11:29 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Ok you got me
Starting over, which end of the car is your 4kg Lithium battery?
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #1705803
03/13/15 01:11 PM
03/13/15 01:11 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
BBMopar -- The SB will always give better handling as its considerably lighter in the front end. Of course, the BB offers so much more torque.
If you ever get those FF 1.12 TBs and install them, you'll really like them!
A friend (John Sandberg) has 1.14 TBs in his original-owner daily driver 340 4spd fastback BCuda Formual S, with Konis, and 16x8 rims 245-50-16 Yokos and the car rides and handles great.
Brian Garcia (aka Cudapilot) has 1.18 TBs in his vintage-race BCuda GT1 car... car handles great on the track!
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #1705804
03/16/15 01:04 AM
03/16/15 01:04 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The day after the bar broke I already decided to order a pair of 1.12" bars from Firm Feel.
But since they were in back order at the time I still haven't seen them.
My Dart still has the SB and I recently upgraded to an alum 4bbl intake from the cast iron 2bbl intake.
But I still want to add some reinforcements like inner fender and radiator support braces and front/rear torque boxes to firm up the body a bit more.
You may want to get in touch with them. I've been e-mailing them about t-bars for my car and according to Matt @ Firm Feel the 1.12" A body bars are in stock- as of last Friday. That's the size that was recommended to me for my car and intended usage.
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #2294642
04/26/17 07:23 PM
04/26/17 07:23 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
Hello... wave Topic update!
2 years since the last reply in this topic, torsion bar no.2 has failed (on the passenger side).
This bar was still one from the first purchase, not one of the replacement bars.
At the time I only replaced the 1 broken bar since the warranty bars arrived.
This time the failure happened under somewhat similar instance (cold morning, speedbump), only I encountered the speedbump faster than usuall this time.
Also, the passenger side header had been rubbing the torsion bar for a while, as can be seen in one of the pics.
Eventhough, I think I'm seeing similar, although to a lesser extend, material defects as with the previous failure.
So now both 'warranty bars' are under the car, but I still like upgrade to a bigger bar in the future.
Funny detail is that Just Suspension doesn't seem to carry these bars anymore on their site.
Carnage pics;
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #2294655
04/26/17 07:58 PM
04/26/17 07:58 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I wonder if that brown/tan discolored area is where the header was nearby? I can't imagine that hot exhaust pipes near a tempered steel part are good for it.
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #2294658
04/26/17 08:12 PM
04/26/17 08:12 PM
The Netherlands
The Netherlands
The header rubbed/contacted the bar a few inches to the front, as can be seen by the shiny spot in the first and 2nd pic.
I could imagine the header could have pushed against the bar and caused breakage over time in the nearby area, but most of time I heard the header vibrate against the torsion bar.
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: Molloy] #2299171
05/04/17 09:33 PM
05/04/17 09:33 PM
IN
ahy Offline
ahy  Offline
IN
Originally Posted By Molloy
The thing about T-bars, I'm sure all of you know, is that they take an insane amount of abuse, by design. They are hanging down there, totally exposed, for the life of the car. They will all have rock dings, impacts, dents, etc. I know have I have beat the living snot out of mine taking them off and putting them back on multiple times. As-manufactured they already have a pretty rough surface, so I don't think the little stress raisers from over-the-road abuse are going to have much effect. In a nut shell, they have a very high damage tolerance. I think it's pretty rare to even see broken bars in 40+ year old iron. They just don't usually break. At least that has been my impression having been in the hobby for 20+ years.
But when they do break, in only 1 YEAR after purchase, all sorts of alarms should go off in your head. I think we all agree that there are some fatigue features. But usually 70-80% of a fatigue life is consumed in initiating a tiny crack. 20-30% is consumed in growing/propagating the fatigue crack to final rupture. Maybe this bar started cracking 8 months after installation? What lowered the threshold to fatigue initiation?
And that long flat planar feature? What stress state would cause THAT?
I say infant mortality...
Agree "infant mortality". Sounds like the seller does also as two bars were supplied. From the pics, looks like a couple areas of possible manufacturing defect.
Firm Feel bars have done well for me (E). B/E bars are longer so 1" on an A is roughly same stiffness as 1.12" on a B/E.
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #2301359
05/08/17 09:22 PM
05/08/17 09:22 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Do you recall the original purchase date of those
bars?
I bought a set of 1.00 A body bars from Just Suspension 2/2010 on sale.I thought I'd use them at some point.
There still in the basement, But I'm getting a
uneasy feeling.
Any other bad stories out there?
Thanks, Mike
Re: My JustSuspension 1" T-bars - 1 down, 1 to go.... [Re: BigBlockMopar] #2302950
05/11/17 06:14 PM
05/11/17 06:14 PM
The Netherlands
The Netherlands
I bought them around July 2013.
Page 4 of 4 1 2 3 4
