Indy Cylinder Head EZ 295 CC #170501
12/19/08 04:53 AM
12/19/08 04:53 AM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Does anyone know what brand springs come with indy's ez heads? I have the 295cc'd set with the upgraded spring to accomodate a .650 lift. They are a double spring with a Dampner. Also, what kind of seat pressure and open pressure i should see with these springs?
I have a solid roller .621 lift.
Thanks,
Steve
Re: Indy Cylinder Head EZ 295 CC [Re: Plumcrazyracing] #170502
12/19/08 02:01 PM
12/19/08 02:01 PM
Thanks,
Steve
I don't what brand of springs that Indy uses but I would want 250 lbs pressure minimum on the seats and 550+ open. When it comes to valve spring pressures on race roller cams, more is way better than to little Not every solid roller cam has the same lobes so the more radical the lobe the more spring pressures are needed to keep the lifter on the lobe all the time, you don't want the roller to lift off of the lobe or slide down the back side of the ramp
Re: Indy Cylinder Head EZ 295 CC [Re: Cab_Burge] #170503
12/19/08 03:07 PM
12/19/08 03:07 PM
Central Coast
P
P
Central Coast
Thank you for your response. The indy heads have the id locator machined into the head and they use a hardened washer on the bottom. Any ideas on what shims (height) i could use to increase open pressure about 100 pounds?
Re: Indy Cylinder Head EZ 295 CC [Re: Plumcrazyracing] #170504
12/19/08 03:57 PM
12/19/08 03:57 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you need another 100#s open pressure, you need different springs.
Re: Indy Cylinder Head EZ 295 CC [Re: BradH] #170505
12/19/08 04:03 PM
12/19/08 04:03 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Use this spring.
http://store.summitracing.com/partdetail...mp;autoview=sku
The std springs they sell are most likly for a hdy, or solid lifer cam. Unless you specified a solid roller when you ordered the heads then it would probabl;y came with the spring listed above.
Re: Indy Cylinder Head EZ 295 CC [Re: Twin Turbo Mower] #170506
12/19/08 04:06 PM
12/19/08 04:06 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
My Indy heads came with Comp springs.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Indy Cylinder Head EZ 295 CC [Re: 1968RR] #170507
12/19/08 04:43 PM
12/19/08 04:43 PM
Central Coast
P
P
Central Coast
Thanks for the help guys.
Re: Indy Cylinder Head EZ 295 CC [Re: Plumcrazyracing] #170508
12/19/08 05:46 PM
12/19/08 05:46 PM
Central Coast
P
P
Central Coast
Okay, got everything figured out. Appreciate everyones help.
Steve
