Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Another Gen-III Hemi E-body swap [Re: RylisPro] #1704809
02/24/15 02:30 AM
02/24/15 02:30 AM
Sac, CA, USA
N
ntstlgl1970 Offline OP
N
Sac, CA, USA
gotta keep in mind that the chinese rods are copies of the high end rods, so I would not be surprised if they look similar. I'll post up pictures of mine in a little while
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704810
02/24/15 11:26 AM
02/24/15 11:26 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I got in touch with Arrow and apparently these are Callies Ultra H beams.
I didn't need the Dyer I beams since I'm not running boost or a ton of torque/hp
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Another Gen-III Hemi E-body swap [Re: RylisPro] #1704811
03/03/15 08:04 PM
03/03/15 08:04 PM
Sac, CA, USA
N
N
Sac, CA, USA
Called milodon and the guy says 3-4 more weeks for the pickup. I'm calling summit to cancel my order. I'll make the durango pickup work. F_U milodon.
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704812
03/03/15 11:16 PM
03/03/15 11:16 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What a collection of ineffectual assclowns.
Re: Another Gen-III Hemi E-body swap [Re: Kern Dog] #1704813
03/03/15 11:35 PM
03/03/15 11:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Truer words have never been said...
Mopar to the bone!!!
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704814
03/04/15 01:02 AM
03/04/15 01:02 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Man that really sucks! I was hoping that my calling in for the pick-up would also get yours made as they said that a few others would get plated?
A custom pick should not be too hard to weld up
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Another Gen-III Hemi E-body swap [Re: RylisPro] #1704815
03/04/15 01:48 AM
03/04/15 01:48 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Just before you shook their tree, Rylis, they had sent me an e-mail saying I was looking at mid-March. Then a couple days later, I got shipping confirmation. I was hoping everyone who was waiting was gonna be taken care of...
2 Demons...no, not my kids!
Re: Another Gen-III Hemi E-body swap [Re: 4speeds4me] #1704816
03/04/15 02:19 AM
03/04/15 02:19 AM
Sac, CA, USA
N
N
Sac, CA, USA
I called summit and cancelled my order. The guy I talked to at Milodon made me feel less than confident that anything would be done soon.
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704817
03/04/15 08:24 PM
03/04/15 08:24 PM
Sac, CA, USA
N
N
Sac, CA, USA
I dropped my parts off at the machine shop, they said the crank should be ok. Depending on the timing, I might have them put the short block together. turnaround looks like 2 weeks. that leaves me 3 weeks to get it together, put it in the car, finish the wiring, tune and head down south. Sure! no problem!
Spring Fling is starting to look iffy.....
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704818
03/08/15 03:11 PM
03/08/15 03:11 PM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
who did you use for the machine work in Sac? hopefully you make it to spring fling. What model pickup number are you looking for from milodon? I have a pan and pickup I got a few years ago. give me a call or text
Jason
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: Another Gen-III Hemi E-body swap [Re: haddixj] #1704819
03/08/15 06:59 PM
03/08/15 06:59 PM
Sac, CA, USA
N
N
Sac, CA, USA
I ended up going to Rex Hutchison in Sac on recommendation of friends. I'll get in touch with you about the oil pan. Thanks Jason
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704820
03/11/15 03:51 AM
03/11/15 03:51 AM
Sac, CA, USA
N
N
Sac, CA, USA
And because I don't have enough stuff to do, I found one of my rocker shafts is bent (maybe that is why there were bearing issues) and I need to replace the pump on my transmission because the gear ate the stator support. Good times!
At least a new rocker shaft, with rockers is $89 from the dealer - quite reasonable...
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704821
03/11/15 02:43 PM
03/11/15 02:43 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You think your bellhousing could've been off of index? Seems odd it ate itself that quick.
Re: Another Gen-III Hemi E-body swap [Re: 72Swinger] #1704822
03/12/15 11:06 PM
03/12/15 11:06 PM
Sac, CA, USA
N
N
Sac, CA, USA
The pump gear ate into the stator support face, like there was a thrust issue or not enough clearance. There was some damage to the converter too that I have to have fixed. I thought I had enough clearance, but maybe not or maybe I ballooned the converter - which would be weird since the 440 that was in front of it didn't make a huge amount of power. The front pump bushing actually looked pretty good so the converter to pump drive tube concentricity was close. At least with the small block case, I don't have to deal with centering the bellhousing on the front pump bore like you have to do with the JW ultrabell. Got the pump today, so I am hoping to get the trans air checked and buttoned up tonight.
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704823
03/12/15 11:31 PM
03/12/15 11:31 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I got ya, my head was thinking drum bushings, not thrust washers.
Re: Another Gen-III Hemi E-body swap [Re: 72Swinger] #1704824
03/19/15 04:34 AM
03/19/15 04:34 AM
Sac, CA, USA
N
N
Sac, CA, USA
I've got the transmission back together and everything checks good. Converter isn't back yet. Engine is still in progress at the machine shop.
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1704825
03/19/15 08:02 AM
03/19/15 08:02 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey just a heads up,
I pulled my radiator yesterday and when I checked the zinc anode it was all ate to crap. I had last checked that thing about 2 years ago and it was still in good condition. My radiator still works fine no leaks so I didn't think the galvanic corrosion would be that bad. I was amazed to find the anode to basically crumble in my hands. With this new motor I went and got a new aluminum radiator and will replace my hoses with some Gates green stripe hoses,
http://www.gates.com/products/automotive...ly-coolant-hose
replaced the steel water neck with an aluminum piece,
and will put in another sacrificial zinc anode. Also going to use some aluminum engine specific coolant and flush more often.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Another Gen-III Hemi E-body swap [Re: RylisPro] #1704826
03/19/15 10:03 AM
03/19/15 10:03 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Use the Chrysler orange HOAT coolant. Lasts a long time and it's what the new Hemi's are tested and born with.
Re: Another Gen-III Hemi E-body swap [Re: 73MagDuster] #1812126
04/26/15 03:48 AM
04/26/15 03:48 AM
Sac, CA, USA
N
N
Sac, CA, USA
Picked up my parts from the machine shop yesterday. I'm now the proud owner of a torque plate. Really messed up my budget but I didn't have a choice. So today I went to start assembling the short block. I was just going to throw the crank in there are run it but thought better of that and set up the dial indicator, lay in the crank and check it for straightness. Done for the day, crank is bent about .0035". Not sure what that is about. Since they had to send the crank out to get ground and I did not have them assemble it, I can't blame the machine shop I guess. I could straighten it myself, but that would require me to build some V blocks - besides I just spent some money to have it worked on. Since I paid someone to grind the thing, I'll talk to the machine shop on Monday and have them straighten it. Disappointed that the place that ground the crank either didn't straighten it or it bounced around in the truck on the way back to the machine shop.
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #1812132
04/26/15 05:03 AM
04/26/15 05:03 AM
Victoria B. C Canada
gold66cuda Online content
gold66cuda  Online Content
Wow,if you didn't have bad luck you wouldn't have any luck at all!
