Page 6 of 9 < 1 2 3 4 5 6 7 8 9 >
#1812814 - 04/26/15 11:24 PM Re: Another Gen-III Hemi E-body swap [Re: gold66cuda]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Eh - I'm pretty stubborn and patient so I'll get through this. It's a mopar thing right?
#1812823 - 04/26/15 11:54 PM Re: Another Gen-III Hemi E-body swap [Re: RylisPro]
autoxcuda Offline
Loc: So Cal
Originally Posted By RylisPro
Hey just a heads up,
I pulled my radiator yesterday and when I checked the zinc anode it was all ate to crap. I had last checked that thing about 2 years ago and it was still in good condition. My radiator still works fine no leaks so I didn't think the galvanic corrosion would be that bad. I was amazed to find the anode to basically crumble in my hands. With this new motor I went and got a new aluminum radiator and will replace my hoses with some Gates green stripe hoses,
http://www.gates.com/products/automotive...ly-coolant-hose
replaced the steel water neck with an aluminum piece,
and will put in another sacrificial zinc anode. Also going to use some aluminum engine specific coolant and flush more often.
Have you done a electrolysis check on your motor? Take a voltmeter and ground the black/neg. and dangle the red/pos. in the coolant with an open radiator cap. Should be less than .3 volts (300 mV).
Are you mixing tap water with green coolant?
Description: This is 76.8 mV
Description: Distilled water, Justice Brothers Radiator Cooler p/n 22p and Cooling System Protector 1csp
Edited by autoxcuda (04/26/15 11:56 PM)
Spring Fling 33
April 13 & 14, 2019
Woodley Park, Van Nuys CA
www.cpwclub.com
500+ show cars, 200+ swap, manf. midways
Malibu Cruise, Cruise-In
Free Spectator Admission!
#1814515 - 04/29/15 10:20 AM Re: Another Gen-III Hemi E-body swap [Re: autoxcuda]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Machine shop got the crank straightened out, it's under .001" now. Made a little progress last night. Looks like I need to shorten and move the oil pump pickup to the centerline of the crankshaft to meet up with the oil pickup area on the pan. I think that it should end up just over #3 main cap, so couple inches forward and about an inch towards the crank centerline. Probably will leave that until the weekend and continue assembling on the shortblock.
Edited by ntstlgl1970 (04/29/15 10:23 AM)
#1815104 - 04/29/15 11:49 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
Hey Eric, what are those marks on the crank counterweight and the main caps? It might be my aging eyes, but it looks like there are some marks or something there.
Looks very clean, the bare aluminum. That is going to be really great!
#1815155 - 04/30/15 01:16 AM Re: Another Gen-III Hemi E-body swap [Re: Frankenduster]
ntstlgl1970 Offline
Loc: Sac, CA, USA
It's the arp assembly lube for the fasteners. If you glance at it really quick, it looks like there are big gouges in everything. I'll get the extra lube stuff off of there before I button the pan up. Fun task of filing rings will start tomorrow.
#1815354 - 04/30/15 11:10 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Going ok....hope to get more done tonight
#1815841 - 04/30/15 07:57 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Loc: Granite Bay CA
It does look like gouges in the metal!
Glad that it isn't!
#1817825 - 05/03/15 03:37 PM Re: Another Gen-III Hemi E-body swap [Re: Frankenduster]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Got the oil pump, timing cover and balancer on. Good thing I have a microwave/convection oven in the garage, had to heat up the balancer hub to get it on the crank since the balancer bolt thread is so deep on these motors, my regular damper installer tool wasn't going to work. Also the FedEx guy showed up just in time so I could install the 3/8 NPT x -10 fittings for the oiling ports in the block. Looks like one of the fittings might be very close to the guard on the back of the alternator once the hose is attached to it, will need to investigate that further. I got all the pistons miked and the shortest rods paired up with the tallest pistons, smallest pistons in the smallest bores, etc. It's going pretty smooth now. Just not fast enough!
#1817860 - 05/03/15 04:44 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Uhcoog1 Offline
Loc: Houston Tx
Looks great!!
Yes- the oil fittings and the alternator are close (touching, actually). My upper 90* -10 end presses up against the alternator cover (the hose end of the 90, not the -10 AN end), and I have to lever the alternator in place. I have that hose going between the alternator and head, so it is angled slightly forward, and that's what causes the most interference.
I have a car alternator. Not sure if the jeep alternator has the same back cover depth.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
#1819141 - 05/05/15 01:33 AM Re: Another Gen-III Hemi E-body swap [Re: Uhcoog1]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Forgot how long it takes to file fit rings, 3 holes down 5 to go. I'll have to spend some more time on the alternator to oil line clearance after I get the long block together.
Edited by ntstlgl1970 (05/05/15 01:35 AM)
#1819147 - 05/05/15 02:24 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
RylisPro Offline
Loc: NorCal
I had to grind down one of the hex's to get mine to fit
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
#1819214 - 05/05/15 08:38 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
72Swinger Offline
Loc: Nebraska
Getting it done! And I bet it will be a better motor than ever now.
Mopar to the bone!!!
#1827194 - 05/15/15 10:23 AM Re: Another Gen-III Hemi E-body swap [Re: 72Swinger]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I hope it will be better than ever - making progress. I think I will be able to drop it in over the weekend. Also got the oil line fitting issue sorted out. Still lots of stuff to do, but things are looking up
#1828556 - 05/17/15 01:40 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Loc: Granite Bay CA
All that aluminum looks great.
#1828570 - 05/17/15 01:59 PM Re: Another Gen-III Hemi E-body swap [Re: Frankenduster]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Got the AC compressor mounted up, cut the compressor, cut the k member, dent the header, grind the motor mount - piece of cake right?
Edited by ntstlgl1970 (05/18/15 01:39 AM)
#1828761 - 05/17/15 07:16 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Loc: Granite Bay CA
If it were easy, JC Whitney would have a $19.95 swap kit to do it.
Guys with determination and skill are a MUST for this sort of thing.
#1828969 - 05/18/15 01:43 AM Re: Another Gen-III Hemi E-body swap [Re: Frankenduster]
ntstlgl1970 Offline
Loc: Sac, CA, USA
there isn't a whole lot of clearance after doing all this stuff, I hope it will be ok....
#1829426 - 05/18/15 05:10 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
RylisPro Offline
Loc: NorCal
I found that the alternator actually hits the AN fiiting I used as oil ports
I had to cut out a portion of the plastic on the back of the altermator to make things all fit
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#1833607 - 05/24/15 10:49 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I think that whoever mentioned cutting the motor mounts off the k member was onto something, what a pain the ... might as well start from scratch.
also including funny picture of me taking a break watching the indy 500
#1833650 - 05/24/15 11:49 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Loc: Granite Bay CA
Looks like the Indy car is about to meet the wall.
25,743 Registered Members
193,014 Topics
I'm back and I survived ! and I have a new Mopar!
by NAS Backyard
Today at 12:36 AM
Largest Tire on cop car rim to fit a 67 Monaco ?
by NAS Backyard
Today at 12:15 AM
1985 Dodge W150
by Neil
Yesterday at 10:51 PM
What brand main and rod bearings do you like?
by vinnyd76
Yesterday at 10:14 PM
