Dodge 2500 oil pan removal and strange diesel like nois #1703610
11/26/14 06:08 PM
11/26/14 06:08 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
can you remove the oil pan in the truck.Does the motor need to be jacked up?The motor only has 84,000 miles but has a rattle under load which kind of sounds like a diesel.Anyone have one and does it make this noise.Oil pressure is great and it runs great except for this suspicious noise.Also the oil pressure is slow to cone up at cold start.I just changed oil and filter with a puolater gold and mobil 10w40.Any ideas?
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: chargers777] #1703611
11/26/14 07:02 PM
11/26/14 07:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure the noise isn't detonation from the winter blend gas?
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: stumpy] #1703612
11/26/14 11:04 PM
11/26/14 11:04 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
A couple years ago the torque converter bolts loosened up on my 89 Ramcharger which made some bad noise and I thought the motor was going south
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: 500ciDuster] #1703613
11/27/14 01:16 AM
11/27/14 01:16 AM
ND
dodgedon Offline
dodgedon  Offline
ND
What engine do you have? V10?
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: dodgedon] #1703614
11/27/14 11:05 PM
11/27/14 11:05 PM
Nashport, OH
Nashport, OH
sorry.v10
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: chargers777] #1703615
11/27/14 11:33 PM
11/27/14 11:33 PM
ND
dodgedon Offline
dodgedon  Offline
ND
Ok, lucky guess! I have heard about some valve train noise and oil pressure issues at start up on the v10. But not sure what the problem was... Seems to me it was a pressure relief valve spring that was bad or found broken when removed... Can anyone confirm this?
67 Charger 383 auto
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: dodgedon] #1703616
12/01/14 04:42 PM
12/01/14 04:42 PM
Nashport, OH
Nashport, OH
I checked the oil pressure spring and it was ok.I can hear motor noise until it builds oil pressure.What makes the oil drainback when it sits?I also changed from a Purolator gold filter to a mopar one with no difference.Can I get the oil pan off to check the pickup?
Re: Dodge 2500 oil pan removal and strange diesel like nois [Re: chargers777] #1703617
12/02/14 11:31 AM
12/02/14 11:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
rattle under load.... reminds me of the detonation prob on the v-10 that would usually take out piston 7 or 9. Crossfire on the ignition cables.
