Re: Engine Storage Cradle Recommendation Wanted
[Re: vinnyd76]
#1703580
11/26/14 06:45 PM
11/26/14 06:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A ratchet strap will fix the "problem" with the Summit cradle. How does the allstar brand mount up front? thru the motor mounts? Timing chain cover bolt holes?
[Re: Vert]
#1703583
11/26/14 08:21 PM
11/26/14 08:21 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Free=old tire Cheap = HD furniture dolly from various sources + a couple short sections of 2X4 and a pair of straps, one to hold engine on dolly, one to hold in place. You can replace the dolly with a small pallet if desired. The dolly is useful once it gets home, unless you have a pallet jack.
