Exhaust Port location #170336
12/18/08 09:45 PM
12/18/08 09:45 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Anybody have an idea of the exhaust port height difference between an 440 block with standard type heads/ Eddie RPM vs. a 400 block with raised exhaust port Indy 440-1 heads?
I believe that the 400 is 3/4 inch less deck height than a 440, how much higher is the Indy heads than the Eddie?
Thanks in Advance
JN
Re: Exhaust Port location [Re: PS Arrow] #170337
12/19/08 09:48 AM
12/19/08 09:48 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Anybody??
Re: Exhaust Port location [Re: PS Arrow] #170338
12/19/08 09:52 AM
12/19/08 09:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know your answer but I thought the 440 block
was only about 3/8" taller
EDIT
I just looked it up and yes its .745
Re: Exhaust Port location [Re: MR_P_BODY] #170339
12/19/08 09:55 AM
12/19/08 09:55 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thanks Mike, you're probably right.
Re: Exhaust Port location [Re: PS Arrow] #170340
12/19/08 10:24 AM
12/19/08 10:24 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
rb block deck heighth is around 10.72. b block around 9.98. i have measured the difference in exhaust port heighth, indy sr vs mopar 906, years ago. if i remember correctly the indy port is around 3/8" higher than the 906.
Re: Exhaust Port location [Re: lewtot184] #170341
12/19/08 10:47 AM
12/19/08 10:47 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thanks. My issue is header fitment, If an RB block with standard heads would be similiar to and 400 block with the Indy 440-1 heads, in regards to port location. I have a very tight fit with an RB and Eddy heads. Basically being cheap and lazy, and trying to figure a way around building another set of headers, while upgrading heads. I dont have short block yet, so looking at going either way, I'd go low deck with Indy if that would work.
Re: Exhaust Port location [Re: PS Arrow] #170342
12/19/08 11:16 AM
12/19/08 11:16 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I assume this is for your arrow,with that said I just went to TTI web site, a-body BB headers RB with stock heads = low deck with Indy or raised port heads maybe this help
Re: Exhaust Port location [Re: PS Arrow] #170343
12/19/08 04:00 PM
12/19/08 04:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Indy SR/440-1 heads have an exhaust port that's not only raised about 3/4" higher than stock, they're also spread out wider than the stock location, too. An 440-1 on a low block probably puts the exhaust port location pretty close to a standard-type head on an RB block.
Re: Exhaust Port location [Re: BradH] #170344
12/19/08 06:37 PM
12/19/08 06:37 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thanks Guys, that helps a bunch!!!
