Changing front tire size #170312
12/18/08 09:02 PM
12/18/08 09:02 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
If you go to a tire that is 1.4 larger in diameter, will the car actually sit 1.4 inches higher?
I need to get about .5 inch more of front end travel and without going into LT tires I find a size that is 1.4 greater in diameter.
After lowering the car back down to its present ride height will that get me the .5 inch I need?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Changing front tire size [Re: Von] #170313
12/18/08 09:05 PM
12/18/08 09:05 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
.70 higher
Mopar Performance
Re: Changing front tire size [Re: moparniac] #170314
12/18/08 09:18 PM
12/18/08 09:18 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yes, half
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Changing front tire size [Re: BloFish] #170315
12/18/08 10:21 PM
12/18/08 10:21 PM
Yes, half
half the diameter goes up from the center of the spindle and the other half goes down
Re: Changing front tire size [Re: Cab_Burge] #170316
12/19/08 01:16 AM
12/19/08 01:16 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Thanks guys. I should have been able to figure that one out. Duh.
