Re: Demon build
[Re: Quickrunner]
#2366390
09/06/17 01:55 PM
09/06/17 01:55 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Wait till ya see the exhaust system that's getting ready to be built.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#2370602
09/14/17 11:28 AM
09/14/17 11:28 AM
Quickrunner
Got my stainless merge collectors jigged up in place, now I can build the headers forward and the exhaust rearward from here. These are nice pieces, got them from Stainless Headers MFG. Fast turnaround also, would recommend them.
Re: Demon build
[Re: Quickrunner]
#2372618
09/18/17 11:24 AM
09/18/17 11:24 AM
Quickrunner
Had a little time to make sparks yesterday, slight mod to trans cross-member. still need to do the other side.
Re: Demon build
[Re: Quickrunner]
#2372713
09/18/17 01:58 PM
09/18/17 01:58 PM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
I remember you back when you put your pants on one leg at a time.... lol
Looks great Dave
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Demon build
[Re: B3422W5]
#2373253
09/19/17 12:22 PM
09/19/17 12:22 PM
Quickrunner
Looks great Dave LOL Don! And thanks! Back then my knees and ankles didn't sound like a bowl of rice crispies after a weekend of crawling in, out, and underneath a racecar
Re: Demon build
[Re: fbs63]
#2380666
10/02/17 04:10 PM
10/02/17 04:10 PM
Quickrunner
Using the 25" long front spring segment? Nice work! Yep 25 inch, thanks
Re: Demon build
[Re: Quickrunner]
#2381200
10/03/17 12:07 PM
10/03/17 12:07 PM
Quickrunner
I can measure the section width on the rears.
I'll have to look at my paperwork, Bob said to use 1.75 backspace on the fronts but I may have measured and snuck in 2.0 I will have to check.
No idea why the old pics don't show up? May have to pm a moderator on that
Re: Demon build
[Re: Quickrunner]
#2390248
10/20/17 11:59 AM
10/20/17 11:59 AM
Quickrunner
Made this stainless plate that will be welded to the pipe and bolted to the floor and will act as the rear support for the system. There is a V-band just below the plate and one over by the quarter panel exit flange.
