Anyone use this crank. I was thinking of a cheap, inexpensive, tight budget 360/408 stroker motor. It would be going in a 72 Dart 4speed 3.91 8 3/4 manual brake, steering steet/strip car, mostly street.
Will it take alot of mallory metal to internally balance this crank? or can I use a stock 360 10.5" external flywheel, or should I use a stock 10.5 internal balance flywheel?
I was thinking about using a edelbrock perf rpm intake with a comp XE286H cam, the J heads I have already have comp 995 springs on them. I was looking for 425/450 hp range. Any ideas, complaints, corrections are greatly appreciated, Thanks guys.
72 360 block (I have)
4.00" scat cast crank
KB 4.030 X 4.00 hyper pistons (I have)
Comp XE286H (.507/.510 284/296)
J heads with 2.02/1.65 mildy ported (I have)
Edelbrock performer rpm intake
Speed demon 750 mech. sec. carb (I have)
360 MP windage tray
Melling HV oil pump (I have)
