Rod bolt clearance #170166
12/18/08 05:19 PM
12/18/08 05:19 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
# 7&8 rod bolts are kissing the cylinder bores , do i chamfer the rod bolts or take the rods/pistons & crank out to clearance the walls.
TIA
Re: Rod bolt clearance [Re: 602heavy] #170167
12/18/08 05:22 PM
12/18/08 05:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would be taking it apart...
Re: Rod bolt clearance [Re: 602heavy] #170168
12/18/08 05:33 PM
12/18/08 05:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cylinder walls
Re: Rod bolt clearance [Re: MR_P_BODY] #170169
12/18/08 05:47 PM
12/18/08 05:47 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Thanks for tellin me what i did'nt wanna hear , will take it appart a g a i n.
Re: Rod bolt clearance [Re: 602heavy] #170170
12/18/08 05:56 PM
12/18/08 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry... try to get then ALL about .045" clearance.
If that one pair is hitting, I'm thinking the others
are real close
Re: Rod bolt clearance [Re: MR_P_BODY] #170171
12/18/08 06:06 PM
12/18/08 06:06 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Yep , will clearance all of em , the old eagle rods cleared the walls fine , these K1s sit a tad higher on the caps.
The piston skirt comes out the hole a fair way (4.625 stroke), so was tryin to avoid cutting the walls any.
Re: Rod bolt clearance [Re: 602heavy] #170172
12/18/08 06:55 PM
12/18/08 06:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We like .050+
Re: Rod bolt clearance [Re: B G Racing] #170173
12/18/08 10:25 PM
12/18/08 10:25 PM
Steel rods and bolts, .030 works also, helps keep the oil off of the rotating assembley a little like a crankshft scraper
