Who has the best SB roller lifter ? #170152
12/18/08 05:16 PM
12/18/08 05:16 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
Who has a roller lifter that basically just drops in ? I've heard stories of some that uncover the oil holes and some that you have to grind on the block to use. Are there any that work good that just drop right in. I have a kit to tube and peen my block, but I have heard some go right in and you dont have to do a thing. It will be a pretty big roller with 1.7 ex rockers and 1.8 int rockers. Thanks for any help
J.C. Childress (434) 665-9541
Re: Who has the best SB roller lifter ? [Re: JC Childress] #170153
12/18/08 06:12 PM
12/18/08 06:12 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Member on here, ou812, Brian, sells custom SB roller lifters from Comp Cams that will drop in witout any clearance issues. They have pretty good shrouding over the roller wheel too. But if you have too much lift, there is NO lifter that will prevent you from having to tube the Block or install bushings in the lifter bores. But his will give you the best advantage.
Go here:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
SRT DEMON ONE SEAT
Re: Who has the best SB roller lifter ? [Re: Ron Silva] #170154
12/18/08 06:38 PM
12/18/08 06:38 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
You didnt say which block you are using..but the BEST roller lifter out there are the crane ultra pro's 5 years thus far with zero issues, nice lifters.
Dropped right in my X block, but i run bushed lifters BECAUSE i pushrod oil with Jesel rocker gear.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Who has the best SB roller lifter ? [Re: JC Childress] #170155
12/18/08 06:47 PM
12/18/08 06:47 PM
SoCal
Brian Hafliger Offline
SoCal
We have the cam's base circle cut down while grinding the cam, to drop the lifter down in the bore more. If done right, you can run as much as a .470 lobe with my lifters.
I'll post pics of them later, but without a reduced base circle, .420 is about the safest to go unless it's checked some how with an existing cam.
Brian
Brian Hafliger
Re: Who has the best SB roller lifter ? [Re: B3422W5] #170156
12/18/08 07:47 PM
12/18/08 07:47 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Re: Who has the best SB roller lifter ? [Re: B3422W5] #170157
12/18/08 08:41 PM
12/18/08 08:41 PM
SoCal
SoCal
Crane's are not the best out there anymore
These lifters are as good or better and they are less $$$!
Crane's are good, no doubt about it, but there is no need to pay more when you can get as good or better lifters from me
Brian
Re: Who has the best SB roller lifter ? [Re: Brian Hafliger] #170158
12/18/08 09:30 PM
12/18/08 09:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I am running the Crane Ultra-Pro's presently and I am very happy with them so far, when I replace them I will call Brian (ou812) and go with his.
Re: Who has the best SB roller lifter ? [Re: dartman366] #170159
12/18/08 09:54 PM
12/18/08 09:54 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I have heard bad about the ultra pro's also,some people have had great luck with them.
I have been running comps as well for awhile and have had zero problems with them,the crowers are also a good choice.
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Who has the best SB roller lifter ? [Re: JC Childress] #170160
12/18/08 10:00 PM
12/18/08 10:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t know about small blocks but, I`m running the isky solid body rollers in my big block and they work w/stock lifter bores and have been working flawlessly for 3 1/2 years street/strip.
Re: Who has the best SB roller lifter ? [Re: Ron Silva] #170161
12/18/08 10:13 PM
12/18/08 10:13 PM
ccarson Offline
ccarson  Offline
Those Lifters are not custom anymore and will be listed in the Comp catalog, I have one of the original two sets produced by Comp they are very stout and drop right in, my lifter bores were bored and bushed which also corrects angle and position of the factory lifter bores.
Re: Who has the best SB roller lifter ? [Re: ccarson] #170162
12/19/08 12:09 AM
12/19/08 12:09 AM
SoCal
SoCal
Yes that's true, but they still act as if they know nothing about them.
I still don't know what price they are giving them....I will say that I can get these lifters in short bodies, tall upper bodies, solid bodies, and the bb lifters in .180 offsets, as well as short and tall bodies...Comp won't stock all those I guarantee that!!!
If they don't have the oil hole in the body running parallel with the axle, they are not the new design.
-Brian
Brian Hafliger
Re: Who has the best SB roller lifter ? [Re: JC Childress] #170163
12/19/08 12:49 AM
12/19/08 12:49 AM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
If you can use a set of Comp 828-16's I have a brand new set still in the box I couldn't use Ill sell pretty cheap. I bought them from Indy but they were too short for my R-3 lifter bores. Ill take $250 for the set. I had to go with the Crane ultra pros which came in a tall version.
Re: Who has the best SB roller lifter ? [Re: a408swinger] #170164
12/19/08 09:54 AM
12/19/08 09:54 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The majority of the sprint car/circle track motors out here on East Coast use Cranes, ISKY's or Crowers, with Crane being most popular.
I use Crane Ultra Pros in almost everything, never had one fail yet.
Re: Who has the best SB roller lifter ? [Re: RyanJ] #170165
12/19/08 10:56 AM
12/19/08 10:56 AM
Big Island ,VA
Big Island ,VA
Its a stock 360 block and the cam will have roughly .400 lobe lift, maybe a tad more. We'll tube and peen it too.
