Alum master cyl- Fluid flow from 1 reservior to other?? #1699940
11/17/14 12:40 PM
11/17/14 12:40 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
Was bench bleeding my new aluminum master cylinder last night and noticed that, as I was topping off the rear reservior, the level of the front reservior went up slightly as well.
I don't think that is right. Can you guys educate me on this?
Re: Alum master cyl- Fluid flow from 1 reservior to other?? [Re: WarEagle1] #1699941
11/17/14 12:48 PM
11/17/14 12:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sounds correct. There is a partial height divider inside the reservoir. Once the one chamber is full, fluid spills over into the other chamber.
Re: Alum master cyl- Fluid flow from 1 reservior to other?? [Re: DoctorDiff] #1699942
11/17/14 05:22 PM
11/17/14 05:22 PM
I see the same thing on all of my newer aluminum Mopar brand M.C.
