Which rear swaybar is this? #1699586
11/16/14 02:40 AM
11/16/14 02:40 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I bought it several years ago. It was supposed to be an OEM E-body unit. I don't think so now. Length is 35 inches. Note the ends. Holes are at right angles to E-body units I've seen.
Re: Which rear swaybar is this? [Re: Vert] #1699587
11/16/14 03:07 AM
11/16/14 03:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My guess is it's an early 70's Addco or Hellwig unit.
I think you are missing on of the axle mounts. The one you have sandwich's between the axle tube them the sway bar bushing.
I have a loose 919 Addco bar and it measures about 35 1/2" eyelet to eyelet
Does the bushing strap at the frame rail have a hole in the side of it?
The 919 sway bar is supposed to be mounted like this.
Re: Which rear swaybar is this? [Re: autoxcuda] #1699588
11/16/14 12:21 PM
11/16/14 12:21 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Thanks for the quick reply. I found your picture when I did a search on rear sway bar. Whats in the picture is all I have. The ends being turned 90° threw me. I'm guessing tracking down mounts might be harder than buying a new unit. Not sure I need one anyway. May have to throw it in the FS area for cheap.
