Working on customers truck..... #1699496
11/15/14 11:35 PM
11/15/14 11:35 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
.....it's the first truck that I've seen with the frame bracket.
Moparlee
Re: Working on customers truck..... [Re: Robbins] #1699497
11/16/14 02:59 AM
11/16/14 02:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I've installed them on a couple of my trucks. Stiffen up the steering quite a bit.
Re: Working on customers truck..... [Re: stumpy] #1699498
11/16/14 11:34 AM
11/16/14 11:34 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I tried posting more pics, they were to big....I took them with my cell phone. Ya I bought one from Direct connection for the Ramcharger a few years back now. I've just never seen one stock on a truck before. I know from reading here and on Ramcharger Central that they are out there..just never seen one yet.
Moparlee
Re: Working on customers truck..... [Re: Robbins] #1699499
11/16/14 12:12 PM
11/16/14 12:12 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Same here. With all the trucks I have owned over the years and all the trucks I have gotten parts off in the salvage yards, I have never seen one either.
Re: Working on customers truck..... [Re: Robbins] #1699500
11/16/14 02:37 PM
11/16/14 02:37 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I try to remember to look on every truck I see, and have only found one.
None on diesels, Ramchargers, 3/4 tonners, etc, finally found one on a 1/2 ton, nothing special, v6 long bed.
Go figger.
To make it better, someone had already taken the steering box, core support, radiator etc off, for great access to it!
Still the only I have run across.
It takes gasoline to interest me.
Re: Working on customers truck..... [Re: VL21] #1699501
11/16/14 05:14 PM
11/16/14 05:14 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ya..this one is a 5.2 short bed with an 833 OD from OK.
Moparlee
Re: Working on customers truck..... [Re: VL21] #1699502
11/16/14 06:37 PM
11/16/14 06:37 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I had an '89 D100 V6 5 spd that had one, not a real heavy duty truck yet it got the brace
Re: Working on customers truck..... [Re: WO23Coronet] #1699503
11/16/14 07:37 PM
11/16/14 07:37 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I need to find one of these.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Working on customers truck..... [Re: Robbins] #1699504
11/16/14 08:25 PM
11/16/14 08:25 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
when the frames started cracking, causing the box to fall off, they started making them. might have been a recall deal, but really it's needed on every truck with that box mounted to the frame. i've only had one truck between '72 and '82 that wasn't cracked at the steering box.
for jamie, put a wanted ad on dodgeconnection. someone will hook you up...
Re: Working on customers truck..... [Re: Golden-Arm] #1699505
11/17/14 02:02 AM
11/17/14 02:02 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Had one on a 89 3.9 auto long bed. Had been wrecked twice and doglegged. Bracket was broken,I assume the frame was diamonds.
Re: Working on customers truck..... [Re: Golden-Arm] #1699506
11/18/14 11:39 PM
11/18/14 11:39 PM
Ohio
HemiD100 Offline
HemiD100  Offline
Ohio
anyone got a picture of one of those brackets off the truck?
edit: found dodge connections page. not promising.
http://www.dodgeconnection.com/catalog/item/2901766/4541374.htm
Re: Working on customers truck..... [Re: HemiD100] #1699507
11/19/14 01:51 AM
11/19/14 01:51 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have a few of those loose if you want more pictures let me know.
