tti header to tti exhaust system, did you do it yoursel #1699086
11/14/14 09:21 PM
11/14/14 09:21 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
I have a 66' HEMI B body with tti headers. I am looking at going from a shop built 2-1/2" system to a tti 3". The web site is not that informative. Have any of you done this "at home" or is a muffler shop still required?
Re: tti header to tti exhaust system, did you do it yoursel [Re: Hemi ragtop] #1699087
11/14/14 09:48 PM
11/14/14 09:48 PM
IN
ahy Offline
ahy  Offline
IN
I did mine "at home". Pretty straight forward. Get the car as high as you can on stands and have at it. The kit was complete and installed as advertised (3" on a '70E). Usually its best to start the install from the rear and move forward. The hardest part for me was getting the exit pipes positioned correctly... took a little trial and error.
Re: tti header to tti exhaust system, did you do it yoursel [Re: ahy] #1699088
11/14/14 09:58 PM
11/14/14 09:58 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Did mine in the parking lot at work many years ago. Plant was closed that day and that's where my tools were.... It was a pretty good days work, but nothing serious. Had to do a little trimming in the back so everything cleared. TTI makes nice stuff.
Re: tti header to tti exhaust system, did you do it yoursel [Re: bobby66] #1699089
11/14/14 10:10 PM
11/14/14 10:10 PM
Tennessee
Tennessee
Thanks for the replies. Did you use their mufflers? and does any one have any before and after tests, chassis dyno #s or mph on the strip?
Engine made 650 HP on dyno with open headers,
Re: tti header to tti exhaust system, did you do it yoursel [Re: Hemi ragtop] #1699090
11/14/14 10:49 PM
11/14/14 10:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i did the full 2" header, 3" exhaust with mufflers on my 65 coronet big block. very easy to install.
Re: tti header to tti exhaust system, did you do it yoursel [Re: lewtot184] #1699091
11/14/14 11:03 PM
11/14/14 11:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Same here as I did mine right on the garage floor. 2" TTI headers with their 3" system out to the rear bumper with an X-pipe. I used Dyno-Max Ultra-Flow mufflers also and I had no problems at all installing mine on my 63. Ron
Re: tti header to tti exhaust system, did you do it yoursel [Re: 383man] #1699092
11/14/14 11:12 PM
11/14/14 11:12 PM
Ohio
billohio Offline
billohio  Offline
Ohio
I put headers and the 3 inch with x pipe on my 67 gtx myself. Easier if you get a helper. I used the dynomax VT mufflers and had to add a short extension. Not the best video but you can hear it. These mufflers eliminate drone. See if this works. http://m.youtube.com/watch?v=Nyoq1B4Lt54
Re: tti header to tti exhaust system, did you do it yoursel [Re: billohio] #1699093
11/15/14 01:32 AM
11/15/14 01:32 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
mine was done when I bought the car...full system including headers...Ive never seen a system that is that solid and well put together...never any weird header noises no rattles no leaks no problems period..im sold for life..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: tti header to tti exhaust system, did you do it yoursel [Re: 72N96RR] #1699094
11/15/14 04:28 AM
11/15/14 04:28 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
2" TTI headers and 3" full TTI system on a RB-motored '65 B-body for me. I was really impressed at how well everything fit. An easy install, did not have to tweek a single piece.
Re: tti header to tti exhaust system, did you do it yoursel [Re: Ramrod39] #1699095
11/15/14 10:46 AM
11/15/14 10:46 AM
Tennessee
Tennessee
Thanks guys, sounds like a weekend job.
Re: tti header to tti exhaust system, did you do it yoursel [Re: Hemi ragtop] #1699096
11/15/14 01:07 PM
11/15/14 01:07 PM
Tti exhaust systems are very nice but wayyyyyyyyyyyy over-priced,i had a custom 3" header back exhaust put on my duster made exactely the way I wanted it with stainless mufflers installed for no where near what tti charges for just their pipes..
Re: tti header to tti exhaust system, did you do it yoursel #1699097
11/15/14 01:16 PM
11/15/14 01:16 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Any pics of the much less costly system?
Re: tti header to tti exhaust system, did you do it yoursel [Re: 1Fast340] #1699098
11/15/14 01:45 PM
11/15/14 01:45 PM
Not at the moment but next time I have it on the lift i'll get you some..
Re: tti header to tti exhaust system, did you do it yoursel [Re: Hemi ragtop] #1699099
11/15/14 04:35 PM
11/15/14 04:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My '71 Charger has the 3" TTI "H" pipe exhaust connected to hooker headers. I had to shorten the "H" pipe a bit because the headers must exit closer than the TTI headers? The super flow mufflers sound good, and are way quieter than the old exhaust a 3-1/2" exhaust with race bullet mufflers that was too loud. Best thing was no loss in performance. With this "H" pipe setup I can get the 727 trans out without removing the exhaust (but I do have to remove one header.)
The '69 Coronet has the 2-1/2" "X" pipe TTI system. I had to shorten the pipes for the exhaust tips. I don't recall if I had to shorten the pipes going into the mufflers?
I wanted to make this exhaust easy to remove, so I welded collector flanges to the back of the mufflers and tailpipe connection, so the whole exhaust can be unbolted and removed to service the manual transmission.
